Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 11-21-2005, 07:52 PM
Rbroekman Rbroekman is offline
Overly active ABS
Hi,
I have a 99 passat and since a couple of days the ABS is overly active. Meaning it starts to vibrate even if the wheels are far from blocking.
It started to do this at very low speeds (around 15mph) but today in the rain it did the same around 40Mph when gently applying the brakes.
Finally after a while the ABS shut down and the light came on.
Anybode familiar with this problem?
Richard
Old 11-22-2005, 09:16 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: Overly active ABS
problably need a new abs module... common problem
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 11-30-2005, 06:57 AM
Will12 Will12 is offline
Perhaps one of the sensors on the wheel could be bad. I had similar problem in Accord.
Old 11-30-2005, 05:23 PM
Re: Re: Overly active ABS
Could be. I did have the break pads and rotors on the frot wheels replaced at Sears. They messed other things up so my confidence in them is not very high.
I'll have VW check it out later this week. Does anyone know how to shut down the ABS temporarily? (Disconnect a plug or something? Removing the fuse caused the BRAKE light to keep blinking).
