Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 11-21-2005, 06:18 PM
01_Celica_GT's Avatar
01_Celica_GT 01_Celica_GT is offline
3sgte vs Monkeywrenchracing 1zzfe
Hey what would be a better choice?
3sgte vs Monkeywrenchracing 1zzfe?
Old 11-22-2005, 08:18 AM
blakscorpion21's Avatar
blakscorpion21 blakscorpion21 is offline
Re: 3sgte vs Monkeywrenchracing 1zzfe
the 3sgte will always be better than any zz engine. sure you could mod a zz to be better but put that $ in a 3sgte and it will be better. inn the 3sgte you not only have super strong internals and an iron block you also have that .2l displacement advantage.
Old 11-23-2005, 09:08 AM
yeah but you cant find a newer 3sgte engine now-a-days. There all going to be way used.
Old 11-25-2005, 01:22 AM
SigmaProjects's Avatar
SigmaProjects SigmaProjects is offline
Send a message via AIM to SigmaProjects
ZZ are lighter as well. More compact. And much more available. Probably not as durable though. I guess it really depends on the build.
RAs, the last of the RWD Celicas... http://truestreets.com/ now out of BETA
Old 11-25-2005, 03:27 AM
Yeah and they are newer. So they have to be more advanced in technology. Maybe not as durable but cooler too.
Old 11-26-2005, 02:15 PM
Vip09 Vip09 is offline
Send a message via AIM to Vip09
In a 7th gen 1zz > 3S-GTE.
If you swap in the 3S-GTE, it will kill the handling characteristics of the car because of the huge increase of weight on the front end. Go with the turbo 1zz.
Here's a quote from Smaay over at newcelica.org. He is one of the most knowledgable people on the site.
Get off the 3S-GTE bandwagon....you gotta remember the 3S is a heavy ass motor and in stock trim is slow...My MR2 was pushing 17psi making about 250WHP and an all motor GT-S pulled on me like i was standing still...you will have to spend about 5-6 grand on the motor itself to make big power...then 10 grand to get it in the f'ing car!!!
Im not a 3S hater, you should know that i have an All-Trac...that has a 3S-GTE in it...i just know by experience what it takes to make a 3S-GTE powerful...and stock it isnt...
Best GT-S STOCK times: 1/4: 14.788 @ 94.98mph 1/8: 9.640 @ 75.87mph
Best Alltrac times: 1/4: 13.3 @ 102mph (older setup) 1/8th: 7.8 @ 83mph (old setup)
Old 11-27-2005, 09:40 AM
Wow, thats good. So he is saying just stick with the zz instead of wasting my time on the 3s-gte?
Old 11-27-2005, 06:42 PM
if ur talkin about swapping a 3s into a 7th gen then id say no just stick with the 2zz but motor for motor i would have to say 3sgte.
Old 11-27-2005, 10:55 PM
calicelica calicelica is offline
Unless you can get yourself an aluminum block 3sgte.... woah, imagine that...
Old 11-28-2005, 08:08 PM
Just import one from japan, big swap shops will do it for you. Cost like 4~5K just for a 3SGE Beams swap and then another 3~4K for a turbo setup. You could go broke real fast building up a new alluminum 3S
