Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 11-21-2005, 05:47 PM
lg2989 lg2989 is offline
pistons
If you get new forged pistons ( low compression ) do you have to redo the break in precedure? What does it take to install the pistons?
And what compression ratio is safe to turbo?
thanks
Old 11-21-2005, 07:22 PM
nisco nisco is offline
Tib Guy
Send a message via AIM to nisco Send a message via MSN to nisco
Re: pistons
thanks
for pistons.. there are tigerlilly, i think i remeber seeing a 2.7 set awhile ago, and RIPP's pistons.. probably a few more, but cant think of them off hand
install depends on the set of pistons you get
i think ripp's are 9.5 maybe....
almost that time
my sig made mommies cry, thats why i had to change it..
Old 11-21-2005, 08:15 PM
Re: Re: pistons
Yeah i found some tigerlillys 8:5:1
so basically all u need to do is get low compression forged pistons and u can turbo the hell outta the engine without blowing?
thanks for ur help!
Old 11-21-2005, 09:20 PM
tibby01 tibby01 is offline
well, there is a long list of stuff.
break in procedure, as with any major upgrade, should be a good 800 miles.
really with this, if you dont know what it takes to install the pistons, you probably would not want to take on the task yourself.
but yeah, lower cr, you can up the boost. your car will be much more sluggish at low rpms though. a little more info can be found on what exactly piston install requires...
here
here
Old 11-22-2005, 09:40 AM
Re: pistons
h...
Old 01-14-2006, 03:59 AM
boztibi boztibi is offline
Re: pistons
where can i find the pistons online? any links?
