Old 11-21-2005, 04:22 PM
Steffe Sweden Steffe Sweden is offline
Send a message via MSN to Steffe Sweden
I need some help with my Windstar -98
I have a problem with my rear parking light....
all the fuses are in good condition.
the problem is that I donīt have any power to the lamps.
the only lightīs who is workin is the breaking and the turning lights.
is it any one here who can help my.....
the car is a Ford Windstar of 98 yaers modell
tanks for some help
stefan in sweden
Old 11-21-2005, 08:11 PM
wiswind wiswind is offline
Re: I need some help with my Windstar -98
Looking at the wiring diagram for my '96...which should be very close to yours...
It looks like your tail lights are on the same circuit as the License plate lamps and your front "parking" lights...the yellow lamps on the sides of the headlamp lens. They are fed by the SAME fuse, the wire color is Brown. The Flashers, turn signal lamps are on a different circuit....and the wire color is Light Green.
Ground is Black.
The Rear Turn signal/flasher is in the same bulb as the parking lights....but uses a different filament in the bulb (1 bulb...2 filaments).
The same is true for the front turn signal/flasher.....there is another filament in the same bulb that serves as the parking light (yellow).
In other words....the lamp that has 2 filaments will have 3 wire colors going to it......Black for Ground, Brown for the "Parking light" and Light Green for the Hazard / Turn signal functions.
My diagram also shows another "Parking" or side marker bulb in the front also.
Do your front yellow lights work?.....then the fuse will be good. It is possible that the filaments in both the rear bulbs for the parking lights have blown. A 2 filament bulb can have 1 filament blow....and the other still work.
It lists fuse #9 (fuse panel inside car) as being for the exterior lamps.
Old 11-22-2005, 04:32 AM
Fuse #9 is good and I donīt have a yellow light in the fron side......
my car is import from germany...
the problem started when i put a trailer to my car....and itīs only the rear parkinglights who dosenīt works...can I get a copy of your wiring diagram?can you email it to me on [email protected].
thanks
stefan
Old 11-22-2005, 02:12 PM
I thanks for the tips but I have fixt my car now....
I can tell you that I found a Power modul for the rear parking light and I found that on the right side in the rear.and here in sweden it cost 3500 sek. so I did a new wire to the rear ligts with a relä and fuse
