Go Back   Automotive Forums Car Chat > Honda > CR-V
Old 11-21-2005, 04:15 PM
Galbaras Galbaras is offline
Send a message via MSN to Galbaras
loud sound from the rear
Hi!
I just bought myself a Honda CR-V 1998 model and have done a few tests just to reassure myself that everything is alright before the used car warranty expires.
During a axeleration test on snow I heard a loud noise coming from down under the rear end of vehicle.
Could this come from the device that tranfers power to the rear axle when the front wheel starts spinning?
Isn't this some kind of a device containing a clutch like mechanism?
Could this clutch slip during a full throttle axeleration on snowy roads?
During a similar axeleration on dry asphalt there is no sound.
The sound is best described as a load hollering.
But the most important question is if this is fixable.
I guess the fix recuires a change of some kind of discs, and that my vendor will be reluctant to do it due to the cost.
Or is this a routine job?
But if this is rooted in a defect, my used car warranty is still active...
Regards
Zadig Galbaras
Old 11-27-2005, 01:36 PM
lorunner lorunner is offline
Re: loud sound from the rear
Sounds like you need to change the rear differential fluid. Make sure you use Honda Dual Pump Fluid ONLY.
Stop asking me about radio codes I cant get them anymore!!!
Old 11-30-2005, 10:15 AM
knightrider5188 knightrider5188 is offline
I have the same problem with my 2001 CRV and i have been told that there is a recall for it. I havent booked mine in yet so cant confirm but call your local dealer and check.
Originally Posted by Galbaras
Hi!
Regards
Zadig Galbaras
Old 11-30-2005, 04:42 PM
There is no recall for the rear diff howling.
Old 12-18-2005, 10:37 AM
jgr7 jgr7 is offline
There is a bulletin out but it is not a recall only advises to change the rear diff fluid at the sever use interval if you hear howling. Had to do my 98 at 65k and now at 142 I hear it again.
Jeff
Old 12-18-2005, 12:30 PM
it really should be changed every 30k but i do it every 15k
