Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 11-21-2005, 04:00 PM
darkerdayz darkerdayz is offline
Send a message via AIM to darkerdayz Send a message via MSN to darkerdayz Send a message via Yahoo to darkerdayz
Lightbulb b18c1 vs b18c5
hey, whats up AF. i have a small problem that i hope y'all can help me with.
me and a friend of mine (not into honda, into VW) are supposed to be having a little friendly competition. its a 1.8L 16v ALL MOTOR competition. we are trying to see who could get the faster car out of the both companies. i'll be using a 88-91 crx (possible an SI) and he'll be using a VW Rabbit (or Rabbit pick up truck).
i dont know whether i should choose the b18c1 or the b18c5. i know the compression ratio in the c5 helps give it the extra horsepower, but is there anything else that helps w/ this (besides the ECU cause i will most likely be going with the HONDATA setup).
also, we decided that as far as CAMS go, we would only use factory parts, but any other part on the motor can be aftermarket, so long as we stay within the 1.8L. from what i've heard, then best all motor cams are from the b16b. can someone give me some clarity on this?
thanks for your help guys.
friends don't let friends drive stock
Old 11-21-2005, 11:52 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: b18c1 vs b18c5
It's around a difference of 10.8:1 (b18c1) to 11.1:1 (ITR). the other differences are the cams and intake manifolds. The ITR has more aggressive cams and a head that comes with a mild P&P, it also can be reved higher. The GS-R has IAB (intake air bypass) on it's IM, not the best design for an IM. And yes the b16b (CTR) cams are the best, well the intake cam is anyways. The exhaust cams are the same with the ITR's, but the b16b's intake cam is more aggressive.
Honestly, go with the b18c1 (GS-R) engine. It's almsot as powerful and is cheaper. Get the CTR cams, an aftermarket intake manifold, and CTR valvetrain (or aftermarket). If you really want to go inexpensive, go with the ITR stock pistons and a thinner head gasket (2-ply).
Old 11-22-2005, 12:23 PM
AllmotorBB6 AllmotorBB6 is offline
Re: b18c1 vs b18c5
whats the price difference in the two motors? And do you ever plan on rebuilding with forged internals?
Old 11-22-2005, 12:51 PM
CivicSpoon's Avatar
There is no Spoon
Re: b18c1 vs b18c5
The ITR engine is about $1,300+ more than the GS-R. Of course depending on where you shop.
