Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 11-21-2005, 02:59 PM
NewyorkKopter's Avatar
NewyorkKopter NewyorkKopter is offline
Turbo Intake Air
Hey, you know how alot of mid-engine race cars have turbo snorkels for the intake air like the Nissan R390 , Audi R8, etc. My question is that instead of using those protuding snorkels, why don't they get the intake air from underneath the car?
this is what the R8, R390 GT1, etc have
why dont they use this way instead of the snorkel that probably add drag?
the R390 and its turbo snorkels
the R8 and its turbo snorkels
Old 11-21-2005, 03:17 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
I would guess because the way the car is streamlined, makes it more beneficial to have it on top.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 11-21-2005, 03:46 PM
but then again if you get rid of the snorkels, the drag will definetly decrease.
Old 11-21-2005, 05:56 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Turbo Intake Air
the drag may decrease if they get rid of the snorkle, but i'm sure that they get better airflow, cleaner air, and less resistance into the turbo which probably helps spool up by using the snorkle.....
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 11-21-2005, 06:00 PM
dimefury's Avatar
dimefury dimefury is offline
it keeps them from sucking up debris
Old 11-21-2005, 08:12 PM
Schister66's Avatar
AF -Advisor
and there's barely any air moving under those cars....
Old 11-21-2005, 10:54 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
and the air under the car is under slight vacuum already
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 11-22-2005, 05:41 AM
so wait what would happen if they used the car under the air?
Old 11-22-2005, 07:30 AM
Schister66's Avatar
AF -Advisor
the air under the car is dirty, full of debris, in a vaccuum, and wouldn't like to enter the engine so there would be resistance to flow which would slow the spool of the turbos and slow the car down. The aerodynamics will suffer very little but the engine likes the nice clean air up top.....
Old 11-22-2005, 02:33 PM
thats true, but what if you put a air filter to prevent anything from entering the compressor section of the turbo?
Old 11-22-2005, 03:04 PM
Reed Reed is offline
Send a message via AIM to Reed
the underside of a race car is a fairly intense vacume whereas the air above the car is higher pressure. Not to mention that it is very difficult to design an undertray that will create the most downforce without having to worry about intakes. Drag is not a huge deal because that can be overcome with a little more power, but downforce is quite hard to come by.
Cars are like music.
If it ain't fast it ain't shit.
Old 11-22-2005, 03:06 PM
this should be in the aerodynamics forum (that doesn't exist) that i suggested a while ago.
Old 11-22-2005, 03:40 PM
o for a second there I was like where? where is it?
but can you find a way to effienciently design the underside of a car, and incorporate intakes for the turbos into it?
Old 11-22-2005, 05:27 PM
If you want your car to fly off the road...like literally leave the payment. You can reduce drag on the underneath of a car, but to actually direct air underneath there for an intake is stupid. Cars are streamlined so the fluid flows over the car, not underneath which helps give downforce and better aerodynamics. Getting rid of the scoop on top would eliminate minimal to neglible drag on that car. If your building a car for a top speed record, then yes, an alternate location might be better to squeeze every tenth of a mph for top speed. For a car like this, its serves no real benefits.
"The CEG Nazi"
www.contour.org
Old 11-22-2005, 09:25 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Gotta remember that there is a pressure drop in that scoop as well... So it isn't really "drag" in the situations that this particular car runs in. It is kinda the same thing as pushing a vacuum cleaner hose forward...
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
