Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 11-21-2005, 02:00 PM
mcnettc mcnettc is offline
Question ranger won't start
My 00 Ranger was running really ruff, like starved for gas, I checked the lines and the fuel pump and they seem to be working fine, changed spark plug and wires because I had it apart and now it won't start at all the battery is good has full charge tries to turn over but seems like not getting gas or something. Can anyone suggest anything to help.
Old 11-22-2005, 08:13 PM
eldiablo1100's Avatar
eldiablo1100 eldiablo1100 is offline
Send a message via AIM to eldiablo1100
Re: ranger won't start
did you put all the wires back in the same order?
Old 11-27-2005, 12:25 PM
Re: Re: ranger won't start
Yes all the wire's are back on, I rechecked theme, I try to start it and it don't get the extra, I can smell gas but it seems like it's not getting to the right place to turn it over.
Old 11-28-2005, 07:47 AM
Psychopete Psychopete is offline
Re: Re: Re: ranger won't start
Are you getting any pops from the exhaust? It seems to be getting fuel, it would most certainly have compression, last thing missing is spark. I'll bet the firing order got fudged. Did you change one wire at a time?
Pete
Old 11-28-2005, 01:27 PM
Re: Re: Re: Re: ranger won't start
Pete
No Pop's, I replaced one wire at a time marking each as I took off. It won't just wont turn over, I took out the fuel injectors and cleaned what I could but it still won't turn over, It don't have the extra it needs.
Old 11-30-2005, 01:30 AM
fordin K fordin K is offline
make sure the plugs you put in are exactly the right type. ford had that waste spark or whateer that had the 2 ground strap plug or what have you and if not replaced with same kind will act up.
Old 11-30-2005, 11:51 AM
I replaced with Bosch platinum plug the exact same as the ones that came out of it. Did I mention that this truck has 160K miles on it? Does it matter?
Old 11-30-2005, 12:56 PM
Re: Re: Re: Re: Re: ranger won't start
So the starter is not turning the engine anymore? I am not sure if I understand what you mean by 'It don't have the extra it needs.'.... If the engine is turning over, but not starting up, look for what's missing... Is it fuel or spark? If you have both, and the engine is turning rough, I would recommend getting the engine to TDC and checking to make sure #1 wire is on the correct plug.
Pete
Old 12-02-2005, 02:25 AM
ok lets start form the basic. recheck make sure spark is proper voltage approx. check fuel pressure. check timing to make sure everything is getting together right and see from there.
Old 12-04-2005, 07:13 PM
acuraracer's Avatar
acuraracer acuraracer is offline
mine did the same thing on my 93 ranger found out it was my ecu might wanna check that
RUNUMHARD/OOFUMHARD
