Go Back   Automotive Forums Car Chat > Honda > RSX
Old 11-21-2005, 01:34 PM
daveersx-s daveersx-s is offline
he's hon-data worth it?
What's up, ive got a rsx-s 2002 with 37 000 kms. A friend told me that a hon-data, is goog way to spent a 1000$. The thing is, my warranty will be cancell! iIs it worth it or not? Will i be able to rev my car like hell with that? Thanks a lot guys!
Old 11-21-2005, 02:40 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: he's hon-data worth it?
there are other tuning systems like Uberdata, Chrome, and Neptune,.......they are almost the same as Hondata, but they are free......
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 11-21-2005, 03:35 PM
Re: Re: he's hon-data worth it?
WHERE CAN I FIND THIS?? Give me more info porfavore? And what will it do to the car; higher rev??
Old 11-21-2005, 04:59 PM
crazy_canuck crazy_canuck is offline
He's just making a useless post, disregard that.
The Hondata is one of the best mods possible for the RSX. Combined with a cold air intake it gives a good boost in performance for a decent price. Everyone who got the Hondata swears by it. It will increase your redline so you will be able to rev more, but remember not to do it toooo much.
Unless you're lucky enough to find a great dealer, the Hondata will cause any engine work that may need to be taken care of under warranty to not be paid for you (i.e. voided). However it cannot and will not void the warranty for any part of your car that the Hondata does not effect.
I do believe you would want to tell the dealer that you have it though just in case they accidentally override it (unless i'm thinking of something else).
Old 11-21-2005, 07:23 PM
Alright, thanks body! I spoke to the technical advisor and he told me that the warranty will be off if i put an Hondata. So i guess i wil wait until i hit 100 000 kms.
Last question, will i be able to rev around 9000 rpm with the hondata?
Old 11-21-2005, 08:22 PM
Not 9000, that's too much for the stock engine to take. It'll be 8400 I think. The VTEC points also get changed and it improves overall engine performance.
Old 11-22-2005, 07:52 PM
RSX-S777's Avatar
RSX-S777 RSX-S777 is offline
Actually, Schister is right...although I hear Uberdata is still slightly buggy. But free is free.
I've got a fever. And the only prescription is more cowbell...
Old 11-22-2005, 08:05 PM
lamehonda's Avatar
lamehonda lamehonda is offline
Revving your engine too high will really decrease your long-term reliability. You gotta modify other things to allow the engine to spin that fast. This will often be at the expense of torque.
Old 11-22-2005, 09:32 PM
mmont0's Avatar
mmont0 mmont0 is offline
With the k-pro I think you will be able to set your rev limit to 9000 rpm. If you do this, you run the following risks:
1. broken valve springs causing #2
2. bent valves causing #3
3. messed up pistons from valves hitting it causing #4
4. no engine for you!
Or is it #1 - #3 - #2 - #4? I can't remember! Either way you still get to step #4.
If you do get hondata and aren't planning on modifying other than a CAI/SRI, I would recommend getting the Hondata #2 or #4 flash first. It's about $500. If you ever decide to go to kpro, they only charge another $500 for the upgrade.
The Hondata #2 keeps the stock rev limit, but lowers your VTEC crossover to a lower RPM. The Hondata #4 raises your rev limit, I can't remember how much, and lowers the VTEC crossover as well. I have read that if you do get the higher rev limit, they don't recommend you go there unless you have modified your internals to better components.
Originally Posted by SBallerk2
yeah...I thinking of trading in my '94 Lude VTEC for an RSX-S
Old 11-23-2005, 09:36 AM
Re: Re: Re: he's hon-data worth it?
That gives me a really good idea! Thanks a lot
