Old 11-21-2005, 11:23 AM
marden1 marden1 is offline
loss of electrical power
I have very little mechanical knowledge. I live in Anchorage Alaska and I can not get my Blazer to start. There doesn't seem to be any power. when I turn the key absolutely nothing happens. My head lights do not come on or anything. I drove it the night before and it ran fine. What might cause such a loss of power?
Old 11-21-2005, 11:39 AM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Re: loss of electrical power
First of all. What kind of car are you driving? Year , model, ect. Right off the top of my head, I would say check your battery and connections.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 11-21-2005, 01:34 PM
Re: Re: loss of electrical power
Sorry, I am driving a 95 Chevy Blazer S10
Old 11-21-2005, 02:07 PM
Gabe25's Avatar
Re: Re: Re: loss of electrical power
Did you take a look at your battery and connections? If the battery check out. Take a look at your fuse panel. If I remember correctly, you have a battery fuse in there. Let me know where your at.
Aloha
Gabe
My Fleet
Old 11-21-2005, 03:42 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Re: Re: Re: Re: loss of electrical power
Battery fuse?
Whats the rating, 650 amps?
It must be HUGE.
Old 11-21-2005, 03:45 PM
Re: Re: Re: Re: Re: loss of electrical power
I'd guess a bad battery, or as Gabe suggests, check your battery connections.
To test the battery, if you have jumper cables, try jumping it. If you get power, most likely your battery bit it.
Old 11-21-2005, 03:58 PM
Gabe25's Avatar
Originally Posted by mike2004tct
Battery fuse?
It must be HUGE.
OK Mike, You got me. I ment to say Engine Fuse. Don't know were my mind was at. I guess that's what's call as a senior moment.
Aloha
Gabe
My Fleet
Old 11-21-2005, 05:01 PM
Re: Re: Re: Re: Re: Re: loss of electrical power
I tried to jump it and got absolutely nothing
Old 11-21-2005, 05:13 PM
the87hyper's Avatar
the87hyper the87hyper is offline
Send a message via AIM to the87hyper Send a message via Yahoo to the87hyper
Isnt 1995 one of the years that they put a crappy ignition switch in thoese? How long did you try to jump it for? If the battery is dead dead, it may take a minute or two to come around. Are you sure you had a good ground when you tried to jump it?
1999 BLAZER ZR2
KENWOOD HEADUNIT KDC-415S
KENWOOD PS-150 AMP
JL AUDIO 10W6
BOSE SPEAKERS 6X9, 4X6
PARNELLI JONES DIRT GRIP 31 X 10.5 X 15
K&N FIPK COLD AIR INTAKE
APC CARBON FIBER TAIL LIGHTS
Re: Re: Re: Re: Re: Re: Re: loss of electrical power
With nothing electrical working, I'd then look at the Positive cable (assuming you put the ground jumper directly to the frame-not the battery) You may just have something as simple as a bad connection right at the battery.
Do you have any type of lights at all with the jumper cables connected?
Old 11-21-2005, 05:15 PM
No, '97 is the switch bastid. 95 has a completely different setup.
Old 11-21-2005, 05:30 PM
Gabe25's Avatar
If the battery is open in side. It will never be able to jump start. You need to use a volt meter and take a reading of the battery. If your voltage is above 12 volts then you need to trace forward to find your open in the battery conections.
Aloha
Gabe
My Fleet
Old 11-22-2005, 11:29 AM
As it turns out it was my battery cables. One needed to be tightened, although I think I may just replace them. Right now the are side posts, I am going to have them mounted on top. Thank you for your help.
Old 11-22-2005, 11:32 AM
Gabe25's Avatar
Glad to of help.
Aloha
Gabe
My Fleet
