Old 11-21-2005, 10:18 AM
Kmizzie Kmizzie is offline
Angry 01 Caravan Blower
Hello, I have a 01 Caravan. And the heater blower only works on high. I read in other fourms that it could be a resistor or somethign like that? Is this the problem? And if so where is it so i can replace it? Thanks
Old 11-21-2005, 11:15 AM
gromittoo gromittoo is offline
Re: 01 Caravan Blower
My 2001 shop manual from DiamlerChrysler for the RS Body type only says "Right Side of HVAC". I would expect to find the HVAC under the dash on the passenger side. Look for box the size of a small suitcase, which would be the HVAC {Heating Ventilation Air Cond.}.
THere are two connectors to the resitor block. One has six pins and the other has two. The six pin connector is black, it doesn't say what color the two pin connector is.
Old 11-21-2005, 08:54 PM
vipergg vipergg is offline
If you have the manual temp control then the resistor is located directly behind the glovebox .
Old 11-22-2005, 08:03 AM
B33p3r B33p3r is offline
Change the resistor block.
Old 12-12-2005, 07:27 AM
HeadlessHorseman's Avatar
HeadlessHorseman HeadlessHorseman is offline
Send a message via AIM to HeadlessHorseman
Yup, Resistor Block alright. That and more: http://www.automotiveforums.com/vbulletin/t340871.html
