Old 11-21-2005, 09:08 AM
blzr95s10 blzr95s10 is offline
Rough Idlle 95 S10 Blazer
My 95 S10 Blazer has a Rough Idle. However it runs great at driving speeds. Before I take it in to a repair shop, I want to see if anyone has any suggestions on what I might try to check myself first ?
Old 11-21-2005, 09:12 AM
Rough Idle part 2
Almsot forgot, I changed the plugs a week ago, they were all fouled, changing them did not really improve the rough Idle. THe engine will idle up and down slightly for about 30 seconds when I first start it, and once it warms up, will smooth out slightly, but still very rough idle?
Anyone experienceing the same problem, or have any suggestions I would appreciate it.
Thankx everyone
Old 11-21-2005, 09:42 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Rough Idle part 2
Thankx everyone
I merged these threads for you..no need to make 2 threads on the same subject.
If you did a search, you would see there are many threads on rough idle and fouled plugs here on the forums.
The most likely senerio is that the CPI unit or the fuel lines inside the plenum are leaking.
Do you see black smoke out the exhaust when you first start the truck?
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-21-2005, 10:43 AM
Cailen Cailen is offline
Sounds like it could be the CPI, so you have a few things to check:
-fuel pressure at the shrader valve (60-65psi is normal)
-look for puddles of fuel / washing inside the intake manifold (remove IMTV and look inside your intake with a flashlight)
-consider changing your cap/rotor/wires if you just did your plugs (unless this has been done recently)
-consider doing other tuneups (ie fuel pressure low, replace fuel filter. recharge or replace air filter. replace pcv valve)
Originally Posted by blazee
If you would pull your f ing head out of your f ing ass and read the f ing thread, you will see that I posted the most common f ing cause in f ing post # 4 and Swalt followed it up with more f ing details in f ing post # 8. From what we f ing posted you should be able to f ing realize that if you have two new f ing tires on the f ing front and two raggedy ass f ing tires on the f ing back... that is probably causing your f ing bang. Try not to be such a tool. Can you do that, Thank you. f head!
