Old 11-21-2005, 08:34 AM
jmat1980 jmat1980 is offline
Thermostat Replacement
Vehicle info: 03 Blazer, 4dr, 4wd, 60k miles
I have some questions about replacing a thermostat on a 03 Blazer:
My SES light came on. I had the code read at auto zone and it indicated a problem with the temperature/thermostat...
It said:
P0128 - Coolant Thermostat (Coolant Temp Below Thermostat Regulating Temperature)
I got the new thermostat and gasket and have instructions on how to replace it.
I dont think the coolant has ever been changed but the levels have always been good.
My Questions:
When I replace the old one should I drain the coolant and replace that as well??
If I do change the coolant is it necessary to completely flush it or can I just drain it from the radiator and install new coolant?
How much coolant will it take to refill the system if I do drain it?
The manual says to use DEXCOOL coolant...Is this readily available at stores like walmart or is it something I need to get from the dealer?
My instructions are for replacing the thermostat are general instructions, does anyone have any blazer specific instructions or tips for me? (I couldnt find the hayes manual for an 03 blazer).
Thanks in advance
jmat
Old 11-21-2005, 10:19 AM
clariveros's Avatar
clariveros clariveros is offline
Re: Thermostat Replacement
Originally Posted by jmat1980
My Questions:
as well??
Do a full flush if you never done one before
the manual say the right quantity,
dexcool is available at walmart and other autoparts stores, make sure it is the orange coolant
2001 GMC Jimmy SLS 2-door Manual Trans 2wd
120K miles and still going - (Not Anymore, ABS screwed me and at 70 mph locked the front wheels and caused me to roll it and it sits in my garage now ) members.cardomain.com/vemucla
2007 Ford F150 supercab lariat 2wd
