Old 11-21-2005, 08:21 AM
DCooper DCooper is offline
Shudder on Acceleration
After warming up, my '99 Taurus, 3.0 Duratec engine, 85K miles, "shudders" or shakes for 1-2 seconds during easy acceleration when shifting into 3rd and/or 4th gears.
I've tried new plugs and new plug wires, and checked around for vacuum leaks. I've changed the transmission fluid 3 times over 85K miles, the last time just after this problem started.
Any thoughts or suggestions? I'm hoping it's a connection or sensor and not the transmission.
Thank you.
Old 11-21-2005, 12:35 PM
Willyum Willyum is offline
Re: Shudder on Acceleration
You use the Mercon V fluid? I put in Castrol Mercon V and on the back of the bottle it says that it cures transmission shudder.
Old 11-29-2005, 12:25 PM
Re: Re: Shudder on Acceleration
Yes, I used Motorcraft Mercon V fluid, which also says it cures transmission shudder. I guess I'll have to take it in. I'll let you know what they say.
Old 12-01-2005, 02:49 PM
The local Ford Dealer said that the transmission technician and the foreman noticed 3 shudders:
Torque converter
Overdrive band
Brakes
They recommended replacing the transmission with a remanufactured transmission with a 3 yr / 36,000 mile warrantee, at $3562.79.
They could repair the existing transmission, but it also would be expensive and only a 1 yr / 12,000 mile warrantee.
I told them I would pick up the car, pay them the $90 diagnosis fee, and think about it.
I'm not feeling well.
Old 12-02-2005, 01:26 PM
I wouldn't feel well either, be sure to look at the Blue Book value before you sink more money into it than it's worth.
Old 12-09-2005, 05:50 PM
FBM FBM is offline
Did you end up having the dealer fix the problem? I had a really strange transmission problem that turned out to be a clogged transmission filter. The car made a screetching sound until the transmission fluid warmed up and could pass thru the filter. I had the filter changed along with the fluid. The noise went away but now I have a shutter from 25 to 30 and 35 to 40 mph. I just added a bottle of Lubegard (green cap) yesterday to see if will help. The verdict is still out.
F]
