Old 05-30-2002, 06:23 PM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
Trivia of the day (Can you solve this?)
It has come to my mind that there are hundreds and thousands of people asking questions everyday in this forum. I figure there must be some people out there has learned something instead of just thinking it's another place to chat. Feel free to post your answer with explanation (it doesn't matter if it's right or wrong) to see if you can solve this problem, also to see if there are any intelligent minds out there.
The situation is like this, my car's RPM is fluctuating while idling from approx. 900RPM to 1500 RPM. Check engine light is not on and there is no previous problem exists in the engine. What could this problem be and how to fix it?
I am pretty sure what the problem is already, I will double check and post up the answer tomorrow.
Hint: I have taken out the injectors and ran them through the injector cleaning machine and tested, then replace them back.
For those who are interested in the result from the machine, the details are below:
Flow % - Cyl #1=100 #2=100 #3=100 #4=100
Pintle % (24MS @ 7200RPM) - Cyl#1=99 #2=98 #3=100 #4=98
Leak Down Test- 60 PSI and above (didn't want to turn the PSI too high since the spec is 40-47 PSI)
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 05-30-2002, 06:54 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
is the rpm "bubbling" up and down, or is it smooth at 900, then smooth at 1500, then back to 900, etc.?
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 05-30-2002, 07:45 PM
Tofuboy's Avatar
RPM is smoothly fluctuating from approx. 900 to 1500 RPM
ex. smoothly from 900 rise to 1500 RPM and smoothly from 1500 drops back to 900 RPM and repeats over and over.
95 Civic EX
83 Toyota Starlet
Old 05-30-2002, 07:55 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
The problem is that you keep hitting the gas pedal with your foot.
You can fix the issue if you stop hitting the gas pedal with your foot lol.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 05-30-2002, 09:56 PM
son of a biscotti... I typed this long-ass response and it didn't post. I hate that.
To me it sounds like a controls problem rather than a problem with hardware (excluding wire connections and sensors).
You didn't say whether or not the car is warmed up, or if that matters, so I'll assume that the behavior is the same hot or cold.
You've recently cleaned the injectors, so potentially they're flowing better than they were before. If they were flowing especially poorly before, then the long-term injector trim would likely be a fairly high value. I would expect that the short-term injector trim would be adjusted to compensate (assuming closed-loop operation) and you'd see no problem.
I'd start by looking at the IAC valve and the circuit that controls it, to make sure that the inputs and responses are correct.
dunno... post the solution when you find it, I'm interested to hear what it is.
Old 05-31-2002, 12:36 AM
kane2g kane2g is offline
Send a message via Yahoo to kane2g
if it doesnt go away after warmed up, i would suspect fast idle valve. I just replaced it on a 92 lude and it was doing exactly what you said.
92 fastback 240sx AKA Ess1Tree Cuz its green, and hasn't moved in months.
Old 05-31-2002, 01:07 AM
Tofuboy's Avatar
Nice approches. This is happening during warm engine idle. Note that there were no previous problems at all and there is no check engine light. Engine was running like a champ.
The injectors were working fine I just felt like giving them a bath.
95 Civic EX
83 Toyota Starlet
Old 05-31-2002, 03:19 PM
b16a3sol b16a3sol is offline
check your air filter and PCV valve.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 05-31-2002, 03:59 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
id check the throttle position sensor, as well as your idle control arm and your idle sensors.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-31-2002, 11:12 PM
Tofuboy's Avatar
Ok, here is what I did.
At first I was suspecting a vacuum leak around the injectors from removing and replacing them as I might have damage the O ring(s).
The reason why I would think it's a vacuum leak is because:
There is no check engine light, which it would be impossible that the IACV is not working plus that I have taken out the injectors.
So I started the engine, let it warm up, idle and try to hear for the leak as the RPM speed going up and down, but I couldn't hear any, at this point I have change my mind about the vacuum leak as the problem (I will explain why I change my mind later). But I used the propane method to try to find the leak anyway, thinking to myself that I probably couldn't hear it as the engine noise is covering it.
After using the propane method and no leak was found, so I have proven my point on changing my mind on the problem was right. The reason that I changed my mind was because I was thinking that if a vacuum leak that can make such a noticeable difference on idle, there is no way that I can't hear it.
So I have move on to my second though as the IACV is probably not working properly. After removing two bolts and two hoses that attach to it, I have taken out the IACV. Inspecting and found that the IACV, the air passage and the screen that filters the air are pretty dirty, so I used some crab cleaner to spray them clean and replace the IACV back and WOW LA the engine is idling properly again.
The reason why this would have the fluctuating RPM symptom is because the idle circuit has some dirt buildup causing the idle to drop and the ECU is detecting that and attemps to raise the rpm before the engine die, as the rpm being raise to a certain point the ECU is detecting that the rpm is too high and try to lower it back resulting the fluctuating idle speed.
Ivymike was pretty close to finding the problem, great thinking!!
95 Civic EX
83 Toyota Starlet
Ok smart people, can you solve this? xviciousx COMPLETELY off-topic 20 01-19-2006 09:26 PM
Can You Solve The Mysterious Hunting/idle Fault 96 Escort 1.8si? matt77earl Escort 3 07-22-2004 09:27 PM
