Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 11-20-2005, 08:43 PM
neonowner97 neonowner97 is offline
Question Compressor question
Is it normal for my A/C compressor to come on for about 5 seconds then shut off for a long time before coming back on for another 5 seconds while I have the defroster on?
Shouldn't the compressor stay on constantly when I have the defroster engaged?
Old 11-21-2005, 11:12 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Compressor question
A/C should kick on with the defrost on to help remove moisture from the air. It may or may not stay on all the time. The defrost does need the A/C to work correctly in order for the defrost to work correctly.
Old 11-22-2005, 07:50 PM
eldiablo1100's Avatar
eldiablo1100 eldiablo1100 is offline
Send a message via AIM to eldiablo1100
late model cars use the A/C to cycle air to dehumidify it in defog mode. it's normal for the compressor to kick in every now and then
Old 11-24-2005, 09:24 AM
Re: Re: Compressor question
There is a way on our neons to keep the A/C compressor from tuning on in the defrost mode, if you wanna save on gas.
Old 11-28-2005, 04:03 AM
nimitz23ky nimitz23ky is offline
Send a message via AIM to nimitz23ky Send a message via Yahoo to nimitz23ky
you can remove the a/c compressor, but all it does is save on some wieght. it does keep it from kicking on, though...
Old 11-28-2005, 07:29 AM
There is a mod people can do to keep the A/C from coming on when in defrost mode.
Old 11-28-2005, 04:58 PM
Re: Re: Re: Compressor question
Thanks for all the info but I think my question was misinterpreted. I was concerned that the compressor was not coming on as often as I thought it should.
Even when I turn the actual A/C on, the compressor doesn't respond. The outside temperature has been around 0 C (32 F), so I'm not sure if that has anything to do with it.
The only time the compressor engages is after I've had the defroster on for a little while and then it only comes on for 5 seconds and turns off for quite some time before it comes on again for another 5 seconds.
Is something wrong with it?
Old 11-28-2005, 05:05 PM
Re: Re: Re: Re: Compressor question
No.
