Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 11-20-2005, 08:05 PM
berth berth is offline
Question 98 Chevy Tahoe MAP Sensor
Car sometimes has no power until it gradually reaches 40 MPH then it runs OK. This problem usually happens on cold days. I suspect the MAP sensor is not working correctly but I can't find it even though I have found a photo of it. Where is it located. Any other ideas on what may be the cause of the problem?
Old 11-21-2005, 09:56 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: 98 Chevy Tahoe MAP Sensor
The Map sensor is located on top of the intake plenum.
There are many things that can cause a hesitation or lack of power.
First I would check to see if the trans shifts through all the gears..if the trans defaults it will start off in 3rd gear.
Do you have a SES light?
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-21-2005, 05:35 PM
Re: Re: 98 Chevy Tahoe MAP Sensor
Thanks very much for your help. I drove the car again today and I noticed that the revs were very low when the problem happened and the SES light came on so I think you're right about it not shifting properly. Also, I didn't know the default was 3rd gear. Do I need to take it to a transmission shop or is there a sensor I can replace?
Old 11-26-2005, 01:23 AM
rumblefish73 rumblefish73 is offline
Re: Re: Re: 98 Chevy Tahoe MAP Sensor
I have a 98 Tahoe also, the default gear is 2nd unless you punch the gas from a dead stop.
You might try putting the transmission in 1st gear and manually shift to the next gear once your engine reaches a good RPM (3000-4000).
Be VERY careful not to shift back beyond D into Neutral or REVERSE!
