Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-20-2005, 06:40 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Post Heavy Door Rot Repair: Before after & During
Hey again everyone,
My driver's side door was getting pretty heavily rotted out at the bottom corner. You couldnt see it from the outside, but it was bad. So I decided to do something about it. Fiberglass & resign would be to thin and flimsey for this particular siuation, and I almost thought I just simply had to get a new door. Well, after doing some plumbing in my house I realized how well solding held, so I decided to try to fill the hole in with a sheet of copper and solder it in place. I've posted the pictures of how it worked out. (The last picture makes it look like the car is a different color because of how dark it was outside.)
^Before I started^
^After cleaning out all the loose rust (Worse than it looked)^
^Soldered the 1/16" thick piece of copper in place^
^After some grinding, primer, and paint (Notice I left the weephole intact)^
Old 11-20-2005, 07:49 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
cool
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 11-21-2005, 06:12 PM
RageCage RageCage is offline
Re: Heavy Door Rot Repair: Before after & During
Nice job.
Old 11-21-2005, 08:49 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Wow, does it look that good on the outside?
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 11-21-2005, 09:06 PM
PeteA216's Avatar
yeah, but the outside was hidden by the chrome trim
Old 11-22-2005, 06:30 PM
400wagon 400wagon is offline
looks good. I'm planning on doing that soon too. The body on my wagon pretty rust free except for the bottoms of the doors. I think I'll do some grinding, and then some por-15. The soldering looked like it worked pretty good.
Old 11-22-2005, 06:42 PM
PeteA216's Avatar
Thanks! If you're going to solder make sure the steel that you're soldering onto it very clean (free from rust, dirt, grease) and ground down pretty well to ensure the solder holds. Take some pictures so we can see how it turns out. Good luck!
Old 11-22-2005, 08:07 PM
sure, I'll make sure to take some pictures. It may be a while before I get to it though. may be after the winter, although it would be better to get it done before so it doesn't get worse.
Old 11-22-2005, 10:38 PM
PeteA216's Avatar
Yeah, thats why I decided to do it now so that it woulnt get any worse... then it'd be more I'd have to deal with. It just started snowing here today about a half an hour after I finished putting on my new snow tires. Talk about timing!
Old 11-23-2005, 12:16 AM
I ordered a POR-15 starter kit. $15 for everything I need to cover 12 sq ft. Should be plenty for the bottoms of the doors.
https://www.por15.com/product.asp?productid=301
Old 11-23-2005, 09:27 AM
ddax's Avatar
ddax ddax is offline
Has anyone used POR-15?
How did it work?
Old 11-23-2005, 11:15 AM
How did it work?
You prep the metal and then paint it. It's supposed to work better on already rusted metal. It seals the rust and its never supposed to rust through again. It tells more about it on the website.
