Old 11-20-2005, 05:19 PM
greesemunkee7's Avatar
greesemunkee7 greesemunkee7 is offline
Send a message via AIM to greesemunkee7 Send a message via Yahoo to greesemunkee7
what to do with a grand..
alright i just got a grand cash from this dudes attorney.. long story.. wandering what i should buy?? haha its all going to the camaro. gona start with some hedman long tube headers. maybe electric water pump. what else...? i cant decide
Old 11-20-2005, 06:22 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
Re: what to do with a grand..
First off more info on the car would be better, which engine, what trans etc. If its still stock then the headers woluld be good with a cat back, then if there is enough you could get an intake. Another idea is gears, depending on what you have.
White 07 STI, Bone stock for now
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
that transmission you were saying you needed. what engine you putting in again. and what hasnt been upgraded yet?
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 11-20-2005, 06:57 PM
the camaro had the 2.8 v6 but i ripped that out, im putting in a 383 stroker, and i have a turbo350 coming up from corpus for 100 bucks and it supposedly runs, we'll see. the motor it self is ready to go. im just trying to decide which parts i want to buy now and which ones to buy later. i would like to get gears pretty soon. so thats where im at now
Old 11-20-2005, 06:59 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
full exhaust (headers, !cat, catback), gears, suspension
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 11-20-2005, 07:25 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
Me, I would see how that Th350 looks, get it rebuilt, a new converter, and then go to exhaust.
Old 11-20-2005, 07:34 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
well, if you didn't have headers on a 383 I would track you down and slap you.... twice... front and backhand.
secondly, what specifically have you done to the engine? is it Tuned port, carbed, what? performance parts? what about engine management? are you using factory computer, custom programmed?
is tranny strong enough for your level of power?
Cooling system okay?
if all of this is in order, then I would defintely go with full exhaust, rear gears, carb-metallic brakes (atleast), stiffer suspension, and B&M racthet shifter.
also what about torque converter?
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 11-20-2005, 07:50 PM
the motor is carb'd, as far as the tranny goes, i just want something for temporary use, so i can acually move the camaro around without towing it, then later on i will get a new one. im just taking it one piece at a time bc i dont usually have money to be throwing out because of college. i have a few radiators laying around that would work, i might just use one of those, again, temporarly. i still have to do some more measurements on the motor bc i bought it when it was all put together and it didnt come with any numbers or info. i do know its bored/stroked 3.75/3.25 with a 400 crank, rv cam, edelbrok 650 electric choke carb.
Old 11-20-2005, 10:13 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
get a set of weld drag-lites
Old 11-20-2005, 10:14 PM
Genopsyde's Avatar
The President
and a 4" cowl induction hood
Old 11-20-2005, 10:20 PM
yeah i was thinking about wheels/tires and a cowl, but i want to get it up and running before i mess with the exterior.
Old 11-20-2005, 10:23 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
... save the money and use it when you need it
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
speaking of exterior, i got some flat black rustoleum and sprayed over that white shit they call paint. i think waxing it with animal fecies would have looked better than what it was. but thats just until i get the time to sand it all down and start over and work with bare metal. then ill get real primer and then paint eventually. ill put some pics up of how it looks with the rustoleum, didnt turn out as bad as id thought.
Old 11-21-2005, 04:22 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
id do something with your rear end. a girdle or something...
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 11-21-2005, 04:52 PM
Genopsyde's Avatar
The President
Re: Re: what to do with a grand..
you should save comments like that for private messages.
