Old 11-20-2005, 06:14 PM
4varellis 4varellis is offline
1999 Ford Windstar with no front heat
My 1999 Ford Windstar only has heat in the rear. I have tracked the problem to a little white box in the dash, behind the radio. When you slide the temp selector from cold to hot, or vice-versa, the little box clicks like it just does not have enough power to do what it is supposed to.
This little white box has a small knob in the lower right hand corner with a recessed square hole. This knob feels like it has a shaft that comes out of the back and goes through the firewall to the engine compartment. There is a small black box and a small black plastic canister (about twice a big as a film canister) in the engine compartment, attached to the firewall, just opposite the white box. I assume the shaft from the white box goes onto the black box in the engine compartment? Is this correct?
I have also noticed if I move the selector from cold to hot, I can help the white knob rotate by inserting a screw driver and turning just a bit. This will engage the heater and blow hot air unless you move the selector switch back to cold. Then the white box clicks and only blows cold air.
I unscrewed the 2 screws on the white box assuming I could removed it and replace it, but the shaft coming out of the back seems to be attached and will not come off. I did apply just a little pressure to try and remove the white box, but was afraid to pull to hard. Any ideas as to how the white box comes off?
Old 11-20-2005, 07:23 PM
12Ounce 12Ounce is offline
Re: 1999 Ford Windstar with no front heat
There are three screws.
Old 11-20-2005, 08:47 PM
Re: Re: 1999 Ford Windstar with no front heat
Thanks. Don't know how I missed the third one. When I take all 3 out, will the white box come off easily, or should I expect to find it is attached to wires or vacuum hoses?
Old 11-20-2005, 08:50 PM
Old 11-21-2005, 05:03 AM
There's one elect connector. Fairly easy.
