Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-20-2005, 04:50 PM
LiquidFlyer LiquidFlyer is offline
Whant to cut out....
All the smog crap on my 84 civic wagon. I have a 84 with over 200k. But I just torn down a wrecked 86 with a 1.5 and have that motor on a stand. I realy would like to remove ALL the smog and replace it with either a (2) barrel webber or some other type carb. I dont mind puttin on an after market intake if thats what it takes. I don`t know where th start looking for anything that may be out there. Also I can fabricate just about anything.
Old 11-21-2005, 05:34 PM
Re: Whant to cut out....
^^^bump^^^ Anyone build up these motors?? I`m not looking to cook the quarter mile just change out the carb! To no smog at all....
Old 11-21-2005, 05:45 PM
dimefury's Avatar
dimefury dimefury is offline
i don't work on hondas. i don't really like hondas either, but this might be a good place to start.
http://www.piercemanifolds.com/
one barrel per cylinder, smog exempt, street registered........jealous?
Old 11-21-2005, 05:52 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
honestly if it has 200k on it, leave it alone.......you may end up w/ more problems than you can imagine if you start f**king w/ things
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 11-21-2005, 05:56 PM
dimefury's Avatar
what are you planning on doing with it after you make it no longer street registerable?
what are the smog laws in your state?
i could think of thousands of other ways you could waste money that would be more fun.
Old 11-21-2005, 06:10 PM
Schister66's Avatar
AF -Advisor
to that....
Old 11-22-2005, 08:04 AM
Well I found a 86 wrecked but only had 59k on the motor. I stripped the car and replaced everything in to mine. The other motor is on the stand in my shop.Smog lawa are pretty liberial here. I will retain the cat but want to get rid of the (or most) vacume lines under the hood. The origanal motor is still in the car. I had 2 year old gas in it when I went to smog it 3 weeks ago, with a gutted cat and it still past emissions. Anyway bottom line is if I can get a little more power out of the 1.5 with a different carb less all the smog vacumes thats what I want.
Old 11-22-2005, 11:43 AM
hxgaser hxgaser is offline
Re: Re: Whant to cut out....
Well, more power the better even if it's old... Check out this website.
http://www.redlineweber.com/
These guys sell webber kits and here is the webpage for your application.
http://www.redlineweber.com/html/app...uide/HONDA.htm
I think the kit they are providing is a single carb kit using existing manifold. I am sure you can find dual setup, including the manifold if you search enough over the web.
As far as keeping the vacuum lines, I say just keep the one from the PCV valve to the carb. Have fun.
Old 11-22-2005, 09:22 PM
Thats what I`m looking for..........Thanks hxgaser. I will use that and be real happy. Even with a stock intake I may get a few more horses. But all the routed hoses will be gone. YES it is that simple. Thanks again.
