Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 11-20-2005, 04:26 PM
polishpimp7789 polishpimp7789 is offline
Send a message via AIM to polishpimp7789
Which amp and SUb?
I was thinking of buying 2 12" kickers (l7). Are these subs load and low. If you do not like these subs what kind do u think i should get? Also i have no idea what a good amp would be for these subs. I do not want a really expensive amp but what that will be able to handle the amps. THanks
Old 11-20-2005, 05:02 PM
cficare68's Avatar
cficare68 cficare68 is offline
Re: Which amp and SUb?
L7's are great subs. Buddy of my has 2 l7 15's in his sentra and they sound great. If you want a decent amp check out this site http://www.justamps.com. I would suggest the poweracoustik A3000DB. I had one before I got my cadence amp and it had enough power to push my 4 infinity perfect without a problem and it is only 347.99 before shipping and handling
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads.
Old 11-20-2005, 06:20 PM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
L7 subs are fantastic. If you want cheap anything check out www.onlinecarstereo.com . I have purchased from them a couple times, and everything is 100% new in box. They have crazy ass deals and everything works awsome. Make sure you get a good class D mono amp, otherwise you might run into some problems. But anything with enough power will work. Good Luck
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 11-21-2005, 08:08 AM
eclipsed4utoo's Avatar
eclipsed4utoo eclipsed4utoo is offline
you are looking to spend some money
Old 11-21-2005, 11:48 AM
cficare68's Avatar
Agreed I too have ordered from them and they are a very reliable site and have great deals on big name stuff
Old 11-21-2005, 03:21 PM
Yeah i have been saving money for my car and accesories to it since i was like 5. All my money is leaving me but in return i get and eclipse with a kick ass system and hopefully i'll put some mods on it.
Old 11-21-2005, 04:16 PM
O also i have been looking at reviews and i think i might go with the poweracoustik A3000DB it seems like it can handle the 2 kickers with ease.
Old 11-21-2005, 07:28 PM
cficare68's Avatar
Re: Re: Which amp and SUb?
Trust me it will like I said I had it pushing 4 infinty prefect 12" and it did a great job. Hit 149.1dbz with the amp. Only reason I got rid of it was because I got a Cadence ZRS10 for 400 dollars (normally a 1400 dollar amp) and it pushes out more power then the A30000DB and takes less draw off the battery.
Old 11-24-2005, 10:07 AM
What is the difference between the 4ohm and 2ohm kicker
Old 11-24-2005, 06:10 PM
rodbls's Avatar
The two ohm speaker can handle more power (assuming your amp can supply it). Ill put a link here to asnwer your qestion my thoroughly.
http://stereos.about.com/cs/componen...speakers_4.htm
Old 11-25-2005, 09:28 AM
Ok would the power acoustic be able to support a 2ohm kicker? probably right? Also can u mix up like a 2ohm and a 4 ohm or does it have to be both the same amount of ohm if u have two subs.
Old 11-25-2005, 01:17 PM
rodbls's Avatar
If you have the power the 2ohm will sound, and hit better. It may draw more current because it needs more power, but you will be rewarded kindly with blowing hair, and girls that get off to vibrations. IDK about mixing, i would go with both 2ohm. Most Mono D amps are 1ohm stable. Make sure that your amp is 1 ohm stable, and if it puts out around 1500-1700 rms power you are set to run 2 12" L7 at 2 ohms. If your amp is not stable at 1 ohm for that much power id be careful because you will fry your amp.
Old 11-25-2005, 06:20 PM
cficare68's Avatar
Yes that amp will do fine. It is Class D, it 1ohm stable and its 2300 RMS and 3000 Peak.
