Go Back   Automotive Forums Car Chat > Kia > Spectra | Cerato | Forte | Mentor
Spectra | Cerato | Forte | Mentor Couple 4 and 5 door models.
Old 11-20-2005, 03:56 PM
studsmilinatu studsmilinatu is offline
Angry My heat doesnt work
My heat doesnt work and just had the battery replaced. I want to know if thats part of the problem.
Old 01-07-2006, 10:30 PM
cbeck cbeck is offline
Re: My heat doesnt work
sounds like it would either be a total coincidence or a blown fuse. probably the former...
I'm not a mechanic, I'm the guy people bring their car too when they don't run. I usually scratch my head and tap on stuff, then call the dealer to see if they can help me find the carburetor.
Old 01-08-2006, 10:36 AM
MeettheCreeper's Avatar
MeettheCreeper MeettheCreeper is offline
When you say your heat doesnt work what does that mean???
Does the blower work but no heat coming out???
Do you turn on the blower and it does nothing???
If the blower works and you have no heat check undr the dash on the passenger side and see if the arm that controls the blend door fell off. Just reattach it and clip it in. It will fall off again.
If the blower doesnt work at all. Open the hood and with the key in the on position, rap on the engine compartment fuse box, if you hear the blower start running, you have a melted connection in the fuse box wiring and more than likely the fuse box is melted also.
When you remove the fuse box and turn it over you can remove the junction box connectors, one will be burned and black in the connector. If this is the case the blower is pulling to much amperage and caused the melt down.
This is going to be an expensive fix, if it is done correctly.
