Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 11-20-2005, 01:45 PM
phillipdlee phillipdlee is offline
2003 - V6 : it just died..
I am by no means a mechanic or even close to being knowledgable when it comes to car repair.
I don't know what happened. My wife and I were coming home from dinner and we were sitting at a red light. The car was driving fine, no ligts, warnings, etc.... The light turned green and we started to proceed through the intersection but the car just lost power and would not move half way into the intersection. I press the gas and nothing happened....I turned the car off and it would not start back up. It makes the sound like it's going to start but just won't turn over.
I checked the battery cables to make sure they were secure. We have a full tank of gas, literally just bought right before dinner so we had not even driven 5 miles since filling up. I dont know what to do..
It is a 2003 Malibu, V-6, and it has 68K miles on it.
Any help would be greatly appreciated....
Thank you,
Phillip Lee
Old 11-21-2005, 12:58 PM
ladyk325 ladyk325 is offline
Re: 2003 - V6 : it just died..
might be your fuel pump because the same thing happened to me and that's what it was
Old 11-21-2005, 06:52 PM
maxwedge maxwedge is offline
A990 racer
Since you say this is over your head, get it to a reputable shop, what else would you do here.
Old 11-30-2005, 01:09 AM
Dave S. Dave S. is offline
Wow, that just happened to me. I got 60k miles. I wonder if this is typical. It has all the symptoms of bad/no gas/clogged fuel filter.
Old 12-05-2005, 12:56 AM
aaaroadside aaaroadside is offline
its possible for it to have water in in the gas . the water will block the injection, try putting a bottle of drygas in it. theres a little cap on the left side of the intake, on the end of the fuelbar"usually" , it looks like a tire valve. take of the cap, and turn the key on and push the little pin in the valve with your nail or a pen or something, anyway you will know it your getting fuell cause it will shoot out of the valve. if theres no fuel, check the relay for the fuel pump, switch it with another relay. if that doesnt work its prob. the feul pump itself. i do roadside and i dont encounter many 03's with bad pumps
Old 12-22-2005, 05:26 PM
bdftesla bdftesla is offline
Same thing happened to me last week. Left it idling for 5 minutes while i went into Pizza Hut to pick up an order. Came outside and it was dead. Culprit: Fuel Pump.
Old 12-23-2005, 11:02 AM
slls slls is offline
Thank you,
Phillip Lee
Turn the ignition key to run, do you hear the fuel pump run for 2 seconds?
Old 12-23-2005, 05:00 PM
RahX RahX is offline
it wont turn over like teh battery is dead? or it wont turn over like it just wont start? if its the battery thing, have someone check out the alternator and battery if its that. if its not that have a shop check it out, not to step on your toes but its probably not something you yourself can fix easily.
