Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > General
General news, articles, other.
Old 05-30-2002, 05:41 PM
ricecube77 ricecube77 is offline
Send a message via AIM to ricecube77
Extra parts, need #'s!! (VC Gasket)
Anyone know the part # for the VC Gasket? I'm doing cam swap...
Also, i've heard theres no actual gasket for the oil pan, only silicone sealant. Is any hightemp silicone sealant okay for this?
-Phil
Btw - i went to West Houston infiniti for VC Gasket... they gave me the run around saying i need orings and other bolt crap.... pfff screw them. Mossy nissan set it up easy
Old 05-31-2002, 11:40 AM
NismoPC's Avatar
NismoPC NismoPC is offline
When you get the valve gasket, you should get the o-rings as well. They are part of the gasket kit. Hopefully Mossy did set you up and send you the whole kit. The o-rings are the part of the gasket that goes around each spark plug opening.
They, the dealer, were right. Probably charge you way more than Mossy would.
Brandon
'96 G20 - modified
Old 05-31-2002, 01:56 PM
Mossy is a nissan dealer....
I didn't get a gasket kit with Orings, a few people i've talked to said it wasn't required...
Gasket is part # 13270-53J05 ??? I think. Its labeled Gasket-Rocker..(not sure if this is for my 94 P10... hm...... i thuoght we had solid lifters.)
On the gasket there are 3 semi-circle rubber inserts, ...
-Phil
Old 06-03-2002, 08:53 AM
NismoPC's Avatar
-Phil
Mossy. I know. I meant the Infiniti dealer you went to initially.
As for the o-rings. It does not sound like you got the kit only the rocker cover gasket. The older gasket 'kit' came with the spark plug o-rings seperately. Meaning you ended up with 4 rings in a bag. The newer kits come with a o-ring gasket where all 4 rings were connected by a common connection. It is a one piece unit.
Both kits, old and new, should have two bags in the kit with the actual rocker cover gasket in one and the spark plug gasket/gaskets (o-rings) in the other. If not, you need to get them. They leak too over time and while your in their you should replace it all.
If you start to get oil in the cylinders where the spark plugs are it is becuase of the o-ring spark plug gaskets being old.
Brandon
'96 G20 - modified
What extra parts needed to replace timing chain, 97 Grand Am GT 3.1? Which chain? skseattle Grand AM 1 05-29-2010 04:40 PM
96 Toy Camry LE 2.2L 5S-FE parts needed Maulana Classifieds 0 03-18-2010 01:17 AM
Extra parts needed.....PLEASE 420Hustler Grand AM 4 01-10-2005 09:32 AM
Extra Part? Young_gee Off-Topic 4 10-01-2004 03:03 PM
89' CRX extra parts?? Akid '88 - '91 Civic | CRX | Wagon | Shuttlee 0 06-27-2003 05:48 PM
