Old 11-20-2005, 12:13 PM
mike 32 mike 32 is offline
heat no heat
1999 Taurus SE NO HEAT!! Flush out system until clear, back flush heater core both from left to right side. Got heat for short time. Then flush agian just filling with water only heat was great for two weeks!!!!!
emptyed out system refilled with 50/50 mix. Now only low heat (very little).
Old 11-21-2005, 03:54 PM
Colt Hero Colt Hero is offline
Re: heat no heat
Sounds odd. How about your thermostat? Is is stuck open such that the engine is running cooler than normal? If the coolant is constantly circulating through the system, it's not going to get hot enough to produce good heat inside the cabin. The other thing to check is your air box underneath the dash. Possibly the blend door is not going to full heat, letting in too much cool air. This would be an internal blend door problem (mechanical) or an actuator issue (electrical). Look underneath the dash and see if you can manually move the blend door to full heat (may have to remove the actuator to do this)...
Old 11-22-2005, 12:59 PM
oakleyp2 oakleyp2 is offline
Re: heat no heat
I worked on a 99 this weekend that did not have heat.
1. cut bypass hose and capped where cut at and clamped
2. flused heater core both directions at the core - no good
3. Took both heater hoses off at engine and flused heater core both directions - WORKS GOOD NOW
