Old 11-20-2005, 10:54 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Am I getting a good deal?
I work with a guy who was a GM top mechanic for 30 years and now he is a handy man at the hospital I work for and on the side he rebuilds Corvettes from the ground up. He has his own lift in his garage with probably $50K in tools at the least. He said he would only charge me $35 an hour and I could either get my own parts as cheap as I could or he would get them as cheap as he could cause he connections or we could see who can get what cheaper and mix and match and all he is going to charge me is labor. Seem like a good deal? I also would like a list if anyone has the time, listed in order of importance, of what a full tuneup on a 98LT would be. I am looking for the best wires, best plugs which I know are the ac delco plats and any other aftermarket parts that are better then stock to do this. Thanks Guys and Gals I really appreciate it!
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 11-20-2005, 11:58 AM
2000blazerls's Avatar
2000blazerls 2000blazerls is offline
Re: Am I getting a good deal?
Well I got the AC Delco cap/rotor and Platinum Plugs. I found some Taylor 8MM wires for a good deal.
Grease your front end.
Depending on mileage I would replace belts/hoses if you are really trying to do a full tune up. Hook it up to a scanner and check for any error codes. My throttle position sensor went bad on my Blazer at around 60,000 miles and the scanner found that for me.
Obviously brake pads and rotors.
Check ball joints and other suspension parts. Probably new shocks/springs would not hurt.
Also, go ahead and replace the bulbs in your headlamps/blinkers/tails. If you have not done this it is definitely time.
Check tread on your tires.
Replace the stock air filter with something like a K&N or just do a whole intake upgrade. Might as well change the muffler while you are at it.
Now to do all of this you have to have some cash set aside. Then again you were not very specific. These are just things I have done or am planning to do in the next 3 months.
I already changed wires/plugs/cap/rotor/tires/rims/brakes/bulbs and added the new intake/cat/muffler. Also got a bull guard/M3 mirrors (a bitch to try and put on, have not added them yet) and a oil catch can I just got in Friday.
I have 70,000 miles on my truck right now so all of these things needed to be done, minus the bull bar. and mirrors.
Hope this helps.
Bye Bye Blazer!
http://www.cardomain.com/ride/2159611
Hello Monte Carlo!
http://www.cardomain.com/ride/2445379
Old 11-20-2005, 10:56 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Have him inspect your truck to see what it needs for brakes forst.
$35 an hour is fair.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-20-2005, 11:08 PM
Brakes are all set.
K&N Air Filter
Old 11-20-2005, 11:09 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: Re: Am I getting a good deal?
wrong... 45 an hour is fair, and at the low end of the totam poll anymore, 35 an hour is a snatch it up deal, have him look it over, and have him get the parts, and do a safty check on it...
Old 11-21-2005, 12:26 AM
BlazerLT's Avatar
AF -Advisor
sure, no arguement there.
but I would still save money and do the tuneup myself.
Old 11-21-2005, 12:33 AM
me too, but if you dont know, or are scared to get under there, better off having someone else do it... you would be how suprised how many tune up calls/jobs we get at work from people (even the mid 20's guys) who just dont want to mess around with newer vehicals
Old 11-21-2005, 12:40 AM
BlazerLT's Avatar
AF -Advisor
Gotta point there but seeing he frequents here made me think he could handle himself.
Old 11-21-2005, 01:45 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
I pay 45 for 2 ASE mechanics so 35 is sweet.
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 11-21-2005, 06:11 PM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Hell $35 an hour. Send him down here. Your luck to find a ASE mechanic that will go under $50. where I'm at. Go for it..............
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 11-22-2005, 09:07 AM
Oh I can do all of this myself. But for $35 an hour and he said he will not charge more then 2 hours worth of work if it even takes him that long. I am juts tired of getting dirty and it is cold now so knowing I have a heated garage to stand in and watch is fine with me!
K&N Air Filter
Old 11-22-2005, 09:47 AM
Cailen Cailen is offline
Screw the tuneups, for $35 an hour you should get him to install some JDM parts, like a sweet body kit, maybe a spoiler, an extra loud muffler, and some interior neon.
If you want to just throw money at this thing blindly I would replace the o2 sensors, forgo changing the air filter and order yourself a cold air intake off ebay ($35-50 with cone filter, depending on quality), plugs/wires/cap/rotor, change your diff fluids, do a tranny service, replace pcv, replace vacuum lines, replace front and rear brakes, do a coolant flush and replace rad cap, and finally do an oil change and put synthetic in. Like the others, I would also consider doing your exhaust (muffler would be fairly inexpensive, catback wouldn't be much more).
Hell of a deal though man.
Originally Posted by blazee
If you would pull your f ing head out of your f ing ass and read the f ing thread, you will see that I posted the most common f ing cause in f ing post # 4 and Swalt followed it up with more f ing details in f ing post # 8. From what we f ing posted you should be able to f ing realize that if you have two new f ing tires on the f ing front and two raggedy ass f ing tires on the f ing back... that is probably causing your f ing bang. Try not to be such a tool. Can you do that, Thank you. f head!
Old 11-22-2005, 10:02 AM
BlazerLT's Avatar
AF -Advisor
True enough.
I just like to get dirty and cold.
It is all part of being a Canadian.
Old 11-22-2005, 10:55 AM
Re: Re: Re: Am I getting a good deal?
True enough.
Old 11-22-2005, 01:02 PM
hey man, the civic board is under 'Honda'
