Old 11-20-2005, 09:31 AM
wheels64 wheels64 is offline
95 Lesabre overdrive shudder/vibration
I have a 95 Lesabre with 96,000 miles. During highway driving when the tranny shifts into overdrive I can feel a slight and brief shudder/vibration. I do not feel anything simular when down shifting. Any ideas?
Old 11-20-2005, 02:01 PM
maxwedge maxwedge is offline
A990 racer
Re: 95 Lesabre overdrive shudder/vibration
This can be an engine uder load or a poor TCC engagement issue. It can be hard to diagnose. Do you feel a shudder when accelerating up a grade , say, at 50 or so when the tcc is engaged? If not, you should have trans scanned by a trans tech who can commnad tcc and check slippage and pressures.
Old 11-20-2005, 02:10 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
I agree with Maxwedge on the miss after engagement, however if it is during engagement, you may have the valve body wear as described in the link below. The second link is for the intecepter, which will delay lockup until a higher speed is reached. This will make the misfire problem (if you have that) less noticeable.
http://www.my3cents.com/showReview.cgi?id=8968
http://keyword.netscape.com/ns/boomf...ntecepter.html
Netscape Search
Old 01-29-2006, 01:01 PM
Jeffery58 Jeffery58 is offline
Have you checked your EGR valve? Had the same problem w/my 95 LeSabre (117,000 m)...especially when going up a hill. OD wouldn't disengage going up hills, had to take it in for an oil change-had mech diagnose the OD issue while it was there & it was a faulty EGR valve. Replaced the EGR & car is running like new!
Old 01-31-2006, 12:46 AM
Land_Shark Land_Shark is offline
Was this problem a shudder (as defined by the factory service manual) in drive or overdrive? I'm just curious because my '92 shudders and/or slips usually in overdrive while on an incline, but otherwise seems to be fine.
I might try replacing the EGR just for sh*ts and giggles
Old 02-23-2006, 10:22 PM
cartoooning cartoooning is offline
i have this same problem also please read my post
http://www.automotiveforums.com/vbul...d.php?t=526880
