Old 11-20-2005, 09:00 AM
ladytinny ladytinny is offline
95 Windstar fuse panel
Does anyone have a diagram of the fuse panel or know where I can locate 1
Old 11-20-2005, 09:26 AM
12Ounce 12Ounce is offline
Re: 95 Windstar fuse panel
You can try the following:
http://www.genuineservice.com/default.asp?page=E4
Plug in 1996, the fuse layout should be the same as a '95.
NOTE: This website is often closed. Just keep trying over a few days.
Old 11-20-2005, 05:27 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Usally the liberary has manuals that contain this information.
Dan
Old 11-21-2005, 11:12 PM
PumpItUp PumpItUp is offline
Are you looking for a schematic breakdown of where the wires lead/come and go to or just a snapshot of the panel itself.. ? The fuse block is located under the drivers side of theinstrument panel and contains the flasher unit, relays and a multitude of fuses for most of the general circuits in the passenger compartment area of the vehicle. A snap shot and all the appropriate info should be in your glove compartment manual that came with your vehicle and if you don't have one check Ford or a local wrecker. Good luck lady tinny
