Old 11-20-2005, 12:53 AM
mattbln mattbln is offline
coil pack 1+4 random missfire
I have a 1998 grandprix non supercharged 3800.cheak engine light flashes. scanner says pd0300(random missfire).Next went to missfire data , only to find cyl. 1+4 miss as fast as the scanner can count . The plugs +wires are new . I swaped coils from 5+2 over to the 1+4 , still same problem . I tried a ignition module +coil packs from a different car,still same problem . The engine is low mileage junk yard motor, intalled at the used car lot. The 3800 is out of a buick.The car seems to run fine,but the cheak engine light flashes. I do not feel a miss when driving it.I think it might need a crank sensor,but i am not sure.need help!
Old 11-20-2005, 08:32 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: coil pack 1+4 random missfire
When the SES light flashes it indicates a misfire condition. However, you could be getting false misfires if the engine is not actually missing. When the engine was replaced was a CKP System Variation Learn Procedure (case learn) performed? A case learn must be performed with a GM Tech II machine whenever a new engine is put in or when the PCM has been replaced. The new settings are programmed into the PCM. It does not sound like the crankshaft position sensor has gone bad.
Welcome to the forum.
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
Timeslip 08/12/06
AF Community Guidelines
Old 11-20-2005, 11:20 AM
KX2000GTP KX2000GTP is offline
