severe smoke
daughter has a 94 gt 2.5 just replaced the clutch went to sart it and distributer was bad (replaced) running and not severely smokes -from exhaust she had over filled the oil changed it ran car for approx. 2 hrs to burn out oil in cylinders but still exsessive smoke also has a knock at front(timing belt location) almost sounds like a lifter but wrong place all this from clutch replacment any ideas or suggestions im tierd of her driving my lincoln
Re: severe smoke
haha, my brother just got a lincoln. older then my probe and worth more then the probe
haha, anyway, what color smoke? for quicker responces check out www.probetalk.com-Tom
94 Rio Red Probe GT Hot Shot Cai, Hot Shot Headers, Resonated T.P., Borla cat-back, MSD 6a ignition w/ blaster 2 coil, PRD plug wires, Tokico Blues, Eibach lowering springs, pacesetter sts, and possibly the best thing done to this car yet, a nice $1300 paintjob <------
Re: Re: severe smoke
Re: severe smoke
sounds like headgasket,when you turn it on does it pour out of the tail pipe? also check the radiator if theres oil floating on the water its for sure the head gasket
Just because its a honda dosent make it fast ------------------------------------------- 96 gt-ze 2 1/4" magnaflo headers back,short ram intake ,msd,short throw shifter,eibach springs,fidenza fw,clutch masters stage 2,t3/t4 turbo install soon,poly engine mounts ------------------------------------------ www.probesnw.com www.probetalk.com www.mx6.com |
the smoke could be caused by a blown head gasket, like mentioned before, or leak from the valve shafts ( there is a little umbrella seal in there that may be screwed up). You may also need new rings.
"All good things are wild and free" -Henry David Thoreau |
Re: severe smoke
Over-filling the oil, then driving it are BAD!! Think of that little crankshaft spinning at anywhere from 700RPM to 6000(yikes)RPM, slapping the oil in the oilpan. It's bad, mmmmkay?
