99 tahoe PLEASE HELP
I recently was drving and it seemed as though my tranny was slipping a little from the start almost like a sputter maybe... When accelerating it would subside, utill i would start out slow again... Then i noticed that my SES light came on...i went to the Chevy dealership right away and proceeded to tell them what was happening. They drove it and then put the diagnositc on it and came back and said that it was a engine miss fire code, not thinking i didnt ask them what the code was. But they said that is normal and suggested that i get a tranny flush, which i did and after that they said they have seen alot worse looking fluid(101,000) and that there were no alarming amout of shavings in the fluid. Assuming they must have drove it, because they said it seemed to have cleared it...Leaving the dealership it ran, shifted and drove smooth...Untill i got into it today and it did the same thing...untill it warmed up then i didnt notice it,one thing that i have read is that a remote car starter may have something to do with it but im not sure... I have replaced before this has happend,,,, spark plugs,intake manifold gasget, oil pressure sending unit, oil cooling lines,front a rear u joints, fuel filter, then only thing that i have done diffrent lately is running diffrent gas in it....i normaly run Bp gas or amaco gas same thing...but put shell gas into it.....so im really not sure what could be wrong... i do live in SD so it has been cold if that has anything to do with it .......PLEASE help
A SES light and a misfire is not normal!
Is the light coming on now? If so get the code pulled and post it here. When you do, give as much info as you can..ie: cold,hot, intermittant all the time,
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
Re: 99 tahoe PLEASE HELP
Re: Re: 99 tahoe PLEASE HELP
Re: Re: Re: 99 tahoe PLEASE HELP
Re: Re: Re: Re: 99 tahoe PLEASE HELP
Re: Re: Re: Re: Re: 99 tahoe PLEASE HELP
Re: Re: Re: Re: Re: Re: 99 tahoe PLEASE HELP
Fuel treatments and injector cleaners WILL NOT unstick the poppets and in this case would be a waste of your hard earned cash. Some injector cleaning solvents MAY contaminate the O2 sensors. If you use TOP TIER gasoline and a Techron additive at every oil change this should be sufficent to prevent fuel system concerns
Re: Re: Re: Re: Re: Re: Re: 99 tahoe PLEASE HELP
Merlin the code i found out was PO300 and they said at the dealership that it would be ok to run some injector cleaner though it......i thought about running seafoam as some people said they sware by it....what do you think My problem is that i have to drive it 4.5 hrs tomorrow and im worried about ruining someting.....the SES light came on again last night....what do you think......thanks again merlin |
Tell the dealer to follow the TSB and fix it right the first time.
The vehicle must be properly diagnosed! This involves determining if the poppets are indeed stuck..this will cause a cold misfire as you described. There are several things that will cause a misfire and they must be ruled out. The poppets on these trucks are subject to hydrocarbon build ups that will cause them to stick..this causes a lean condition and a misfire..usually starts as a cold concern, but can become severe enough to create a no start condition. I personally have performed this procedure many times with great success. Injector cleaner WILL NOT fix your concern...all you are doing is wasting your money! Injector cleaner will not work because the poppets are stuck closed and the cleaner cannot get past the ball and seat..this is the reason the unstick procedure in the TSB must be performed..High pressure nitrogen is injected into the poppet..this forces the ball to move of the seat and frees up the poppet.
Thank merlin...Today i had them do a injecter poppet cleaning which costed 120 buck 150 with the bad plug wire...But why they suggested the tranny flush when they said today...that the first time the put it on the scanner it said a random missfire code but noted that two were worse then others,,,, then tell me that they suggest a tranny flush... im in the process of making a rucus... that should have not been the thing done...they should have know that it could be the injecters.... thanks again merlin |
Do not have the trans flushed..especially on a higher mileage vehicle..could cause some problems.
So should you never have the tranny flushed? And by flushed to you mean oil changed as well?
Hello tajah , If you have recently had a remote starter installed in your Tahoe, check to see that the 2nd ignition wire was hooked up, this wire will be the white wire from the igition switch and if not hookup will cause your CHECK ENGINE light to come on and the vehicle will feel sluggish and won't shift properly.
