Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 11-19-2005, 08:25 PM
bjstorm69 bjstorm69 is offline
security vats lock out.
I lost my keys(i know, stupid rings a bell) and installed a new cylinder and key. I had to try many combinations to get the right resistor value. The car runs, but no radio, information center, and not hvac. If i simply plug in a tech 2 (not even turning it on), everything works. What do I do to reset whatever needs to be resent.
thanks
Old 02-01-2006, 08:22 PM
3-pontiacs 3-pontiacs is offline
Re: security vats lock out.
[quote=bjstorm69] hey how are you i am new to the site but i have a question. i just bought a 92 ssei with no keys . it is a stolen recovery . so how did u find th risitance of your car cause i bought a after market key and tumbler did not work . can you help me. thanks
Old 02-09-2006, 05:57 PM
randman1's Avatar
randman1 randman1 is offline
thanks
Geeeeze... that's odd. What year car and is the climate control electronic or manual? I'd like to take a look in the service manuals to find out what's common. Almost sounds like a circuit is being completed through the OBD connector but I've never heard of such a thing.
Old 02-21-2006, 09:31 PM
DaPhattsta DaPhattsta is offline
Usually if you leave the key in the on position for about 10 mins the computer will reset and you should be able to start the car. After the 10 mins make sure you shut the car off before you try to start it but it should reset. Im not sure if the same goes for a new ignition. There is also a way to bypass the vats completly if it's not something you definetly need. If its something you might want to know let me know.
