Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-19-2005, 08:14 PM
crabby760 crabby760 is offline
Major Problems Help!!!!!
i changed my headgasket... and put everything back together.. re did the timing...
started it up and sounded normal... was letting her warm up and about a minute or 2 later... i hear a loud BANG and a super loud metal to metal sound... then the motor just died down and shut off
now it will barely turn on and once it starts it will die rite away..
ANY IDEAS!!!!!!!????? i'm at a loss rite now i have no clue what to do..?
Old 11-19-2005, 10:43 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Major Problems Help!!!!!
Rip it apart (at least take the head off) and see, but it doesn't sound good.
Old 11-21-2005, 12:56 AM
hxgaser hxgaser is offline
I agree pull the head. But first pull the timing belt cover. Did it slip?
Old 11-21-2005, 01:03 AM
can u guys tell me what i should check and how to check it exactly thank u
Old 11-21-2005, 10:44 AM
Well, the simplest thing to do is just pull the top portion of the timing cover off. Depending on your car, you might just be able to unscrew a few bolts/screw for the top cover and just slide it out a little bit to see if the belt is still on the cam gear. I would post a picture, but I don't know how to. Does anyone know?
Anyways, if the belt slipped off, then you might have some serious internal problems. First thing is to check all the valves. Your pistons might have bent them. Then Check the tops of pistons for any visible damage. (This probably is unlikely, but can happen) and check the cam for any scoring and etc. It's good idea to just give the head area a look over to see if anything is abnormal. Even if it looks okay, I would crank the motor manually with out power to see or hear anything unusual. All the valve movements should be normal. I.E) Intake valve(s) open, then exhaust, all in firing order... Don't try to start or turn the motor with the starter again unless you know exactly what's wrong.
Good luck.
