Old 11-19-2005, 05:56 PM
lilsprite lilsprite is offline
Unhappy Heat stopped working HELP!!!
I have a 94 astro with a 4.3 throttle body I just put new water pump and thermostat in it runs great but now I have no heat. The heat worked before i changed these thing but now it doesn't. The fan works fine it's just cold air. What do I do?
Old 11-19-2005, 06:33 PM
CD Smalley CD Smalley is offline
Re: Heat stopped working HELP!!!
Does the temp gauge move at all?
I would bet that the thermostat that you installed has failed in the open position....
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 11-21-2005, 11:01 AM
Re: Re: Heat stopped working HELP!!!
Temp gage doesn't work now either
Old 11-21-2005, 02:04 PM
tableman tableman is offline
Sounds like you have an air lock in the cooling system. Did you run the van with the rad cap off, after you refilled it? This allows air to escape. If you have filled the rad right up to the top, you will want to take out about 3 or 4 cups of antifreeze, then run the engine, if you don't do this when an air bubble breaks loose and tries to escape it will shoot antifreeze out the top of the rad.
Old 11-23-2005, 10:42 AM
drew300 drew300 is offline
GM used to be famous for air locks in the heater system. Do these vans have that problem?
Old 02-27-2006, 09:00 PM
loonytu loonytu is offline
they know to have air lock problems because the engine is lower than the heater core
Old 02-27-2006, 09:37 PM
Kings-x59 Kings-x59 is offline
Let's see, the temperature sensor is in the vicinity of the thermostat isn't it?
I bet you've got an air bubble in the system, right at the thermostat housing- doesn't even have to be in the heater core.
What it means is that your water pump isn't circulating coolant because of the bubble, and your engine is running hot but it's not apparant because the temperature sensor is in the air bubble.
Had this same problem on my Jeep after replacing the radiator hoses.
If running it with the cap off doesn't rectify the situation, unhook the top radiator hose at the thermostat housing. Use a screw driver to Gently open the thermostat and pour coolant directly in till no more will go. Then hook up the top hose.
'89 Astro 4.3L Z
CFM-Tech power plate
2.5" exhaust, Low restriction cat and muffler
Jet stage I chip
B&M trans cooler
'96 Jeep Cherokee
'99 Chevy Cavalier
Old 02-28-2006, 07:19 AM
brcidd's Avatar
brcidd brcidd is offline
You may want to check your heater water shut off valve- underhood right on top of HVAC case- see if it is not stuck in off, bypass position- are your heater hoses hot?
Old 02-28-2006, 05:00 PM
the heater hoses are hot only going in the valve but not after the valve into the heater core so i am assuming the valve is stuck closed so no coolent can by pass through
Old 03-01-2006, 12:42 AM
Aqua Angel's Avatar
Aqua Angel Aqua Angel is offline
Send a message via ICQ to Aqua Angel Send a message via AIM to Aqua Angel Send a message via MSN to Aqua Angel Send a message via Yahoo to Aqua Angel
Talking Re: Heat stopped working HELP!!!
Well i have learned the hard way with my Audi Coupe and my other Audi Sedan and that also applies to Chevy. once you do a coolant flush or any part replacement around the coolant, is to leave that rad cap off until all the air are out of the system. just remove the rad cap, start your van and rev it a few time until you see the temp rise, make sure that you also squeeze the upper rad hose so that you can remove as much air as possible. After reving that engine for 5 to 10 minutes, most of the air should be out of the engine and you will be up and running in no time.
PS don't forget to add coolant when it is getting low.
Good luck.
=D
93, Chevy Astro van, Saphire Blue, Led tail light.
looking for:
Euro clear corner lights and Billet grill "chrome" and a good shinny 5 spoke rims and a disc brake rear differential
