Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 11-19-2005, 03:32 PM
justsaymeth's Avatar
justsaymeth justsaymeth is offline
Exclamation Turn signals
Are there any other components in a 93 Pontiac Bonneville turn signal system other than the hazard flasher and the turn signal switch that can keep them from working? The lights just stopped working last night
Everything else works hazzard, brake, tail, back-up, headlights all work but when the signals are turned on either side nothing happens no blinking in dash or outside the car I been driving with the hazards on and I've checked all three fuse locations any suggestions or help would be greatly appreciated.
Old 11-19-2005, 03:44 PM
maxwedge maxwedge is offline
A990 racer
Re: Turn signals
How about the signal flasher?
Old 11-19-2005, 08:22 PM
Re: Re: Turn signals
I was under the impression that the signal and hazard were one and the same. Are they separate and if so where is it located? The hazard is close to the column on a clip.
Old 11-19-2005, 08:28 PM
bjstorm69 bjstorm69 is offline
Re: Turn signals
sounds like your turn signal relay. It looks just like your hazard relay, just in a different spot.
Old 10-11-2006, 11:29 AM
JOHN22 JOHN22 is offline
Re: Turn signals
SAME PROBLEM WITH 98 WAS HOPING TO CHEAT & READ WHERE TURN FLASHER IS BUT NO INFO. (LOOKS THE SAME BUT IN A DIFFERENT SPOT)ANY IDEA WHAT SPOT????
THANKS, JOHN
Old 10-11-2006, 03:07 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Turn signals
THANKS, JOHN
This is an old thread post about a year old. It is highly recommended to start a new thread with your issue or wait until someone replies to your other one. Thread closed.
POSTING IN CLOSED OR OUTDATED THREADS:
If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
Timeslip 08/12/06
AF Community Guidelines
Closed Thread
