Old 11-19-2005, 03:19 PM
johncliberty johncliberty is offline
new starter, won't start
Just put in a new starter and it worked fine for a few days, now it won't start it won't even click, nothing Put in new starter relay, checked all connections to the starter still nothing. anyone have any ideas?
Old 11-19-2005, 04:27 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: new starter, won't start
It's time to get a test light and a volt meter and go back to basic diagnosis:
1. Does your battery have power? Is it a full 12 volts?
2. Does the relay energising wire (the one that provides 12 volts when you turn the key to 'start') actually have power when you turn the key?
3. Does the fat wire going from the battery to the relay have 12 volts?
4. When you turn the key does the fat wire from the relay deliver 12 volts to the starter motor?
Isolating the problem is the first step to solving it.
Old 11-20-2005, 11:28 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
What year and model?
The later ones have a circuit breaker. Mine had a bad ignition switch that cause the circuit breaker to go out. <97XJ sport>
Take the starter out and test it with jumper cables hooked to it.
Old 11-20-2005, 04:17 PM
Saudade's Avatar
Saudade Saudade is offline
Manual or automatic? Both have safety switches that prevent starting while in gear.
You never mentioned if other electrical items all work.
Follow MagicRat's advice about isolating the cause.
Let us know how you're going.
