Old 11-19-2005, 12:14 PM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
how do you use to remove clay?
Seems Ray get angry this time I try search and I think I know in my mind every word in this site about cast resin, before take words...
No mans, I've a stupid problem: someone of you cast masters know how I could use to remove clay from molds? or do you think I could leave here and put over a lot of releaser, obviously it's only behind the 2 shell, cast area is clean (almost)
May be I use the wrong clay: it's a standard childs modelling clay I think not greasless; over that i use a silicon releaser!
Obviously with 5 nails tech I haven't any problem, but with those rim I need a delimitation line inside, so i need clay (or something other)
please, an advice? thanks
ps: I try tiepid water, alchol but this f*****g clay won't leave from my poor mold
gio
Old 11-19-2005, 01:26 PM
D_LaMz's Avatar
D_LaMz D_LaMz is offline
Re: how do you use to remove clay?
I think you are supposed to use a different clay.
Old 11-19-2005, 02:52 PM
gionc's Avatar
Authorized Vendor
found out
warm water could make something (melt the clay)
so, I need to search the pro clay kind
gio
Old 11-19-2005, 03:12 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
I use Alumilites blue clay. No problems with it at all. Why do you have a pour and vent hole for your brake mold? Those can be a one part mold and pour from the top then scrape off the excess. They shouldnt be there unless you are making a two part mold.
-Mike
Old 11-19-2005, 04:26 PM
gionc's Avatar
Authorized Vendor
Re: Re: how do you use to remove clay?
thanks fo info
well, I just still doing both vent sides with 2 part mold
gio
Old 11-21-2005, 08:36 AM
klutz_100's Avatar
Gio!
Have you used this clay before? I guess not
The only reason I can think of for it to stick so badly is that it must have some form of silicon in its formula. Silicon should only bond with silicon (I think).
Don't be shy scrape away with a tooth pick like crazy!!! Also, try putting the mold in the freezer to get the clay REAAALLLLY hard and then try peeling it off ? What's the worst can happen )
I got me some clay from an artists store since allumite is out of my reach.
ciao!
Old 11-21-2005, 01:43 PM
gionc's Avatar
Authorized Vendor
Originally Posted by klutz_100
Gio!
ciao!
in full sincerity it's just the first time I attempt to cast in 2 shells method: within now I cast only with 1 mould or with 2 moulds and 4+1 nails
so I fix the bug in the opposite way: with warm, also your one seem to work properly
yes: I need to search more around clays: my haven't silicone, it's just a vegetal compound right for childs
HLS and resin provider hasn't clay
thanks steve
gio
Old 11-23-2005, 12:19 AM
bvia's Avatar
bvia bvia is offline
Use Kleen Klay. Made for casting AND will dilute in IPA (of 70% or higher).
hth,
Bill
Bill
"Why yes, that IS my bare, carbon fiber Enzo in Scale Motorsport's "How to Carbon Fiber Decaling video!"
