Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 11-19-2005, 12:00 PM
rmcbri01 rmcbri01 is offline
Torque converter rattle??
I've got an 02 Mountaineer V8 AWD (I know this is the Explorer forum but there's not much action on the Mountaineer one - and heck, they're basically the same vehicles) and my and the Ford dealers first thoughts were that a heat shield was loose. I've got a constant rattle noise whenever the vehicle is running. Sounds like a thin piece of metal shaking against another piece of metal. Ford checked it out and said the noise is coming from the torque converter - which is a whole different story price wise.
Just curious if anyone here has experienced the same thing and what the outcome was.
Thanks a lot.
Old 11-19-2005, 11:43 PM
ixoxoli ixoxoli is offline
Send a message via AIM to ixoxoli
Re: Torque converter rattle??
where is it coming from, the noise?
Old 11-20-2005, 07:55 AM
Re: Re: Torque converter rattle??
I haven't been under the vehicle to try to pinpoint it myself. I'll see if I can do that today. But as I said earlier, Ford diagnosed it as coming from the torque converter. Sorry if I'm not able to provide much info on this.
Old 11-21-2005, 04:38 PM
exploded99 exploded99 is offline
Re: Re: Re: Torque converter rattle??
I have heard of it - not very often, but it can happen. The inside of the torque converter contains a clutch disc very similar to a clutch disc in a car with a manual tranny. When your torque converter goes into lock-up, this disc is engaged using fluid pressure.
There are some springs which absorb shock when the disc engages - every now and then one breaks.
Do a little searching on the internet, you will find some pictures / explanations.
Old 11-21-2005, 09:03 PM
Re: Re: Re: Re: Torque converter rattle??
Thanks exploded. I'm going to take it to a transmission shop for a second opinion before committing to spend the money.
