Old 11-19-2005, 11:40 AM
tigerdevil tigerdevil is offline
defogger problems
i have a 92 RS with a 3.1. I try to turn on my rear defogger and it doesnt work. The little light saying that i turned it on comes on, but that is it, nothing else happens. After a little while that little light shuts off by its-self too. Any one know what the problem could be??? My window is getting frosted and it's hard for me to see or backup...
Thanks anyone in advanced for the help.
Old 11-19-2005, 01:35 PM
CamarosRsweet94's Avatar
CamarosRsweet94 CamarosRsweet94 is offline
Re: defogger problems
There is a problem between the switch and the defroster in the window, maybe a broken wire or something. That's all I can tell you about it.
1994 3.4L Chevrolet Camaro - No more
2006 Hyundai Sonata
Old 11-22-2005, 07:10 AM
CamaroRS92 CamaroRS92 is offline
First thing i would check is the wiring connections to the rear hatch itself.
On the gas support struts are where the connection terminals are located. Unplug each of the 4 (located at each end of the struts on R & L hand side) and be sure there isn't any corrosion (if so scrape it clean) and check for tight fitting terminal connectors, burnt wires ect.
Also, another important thing to consider , if you have had the rear hatch tinted - some of these guys that do window tinting just dont give a shit about your car and will actually trim the tint to fit after it is installed (or as a dry fit prior to installing) and will literally cut or scrape a very thin line thru every defroster element on the hatch with a razor blade. This renders it completely inoperative. If this has happened - you will have to trim the tint back away from the cut spot and repair it. GM has a defroster repair kit available just for this purpose.
Old 11-23-2005, 06:46 AM
J.Cutta's Avatar
J.Cutta J.Cutta is offline
Another way to get that window fog free is to turn on the heat.
http://www.cardomain.com/ride/631458
_______________
92 Camaro V8 TBI 305 with Dynomax 3" Catback Exhaust, ASCD Iroc Turbo Hood, Goodyear Triple Tread Tires, K&N Open Element, Cat Delete, WonderBar Steering Brace, 160 Thermostat
