Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-19-2005, 09:12 AM
HondaTuner20 HondaTuner20 is offline
car started bucking violently at 85mph
I was going down i-84 in newyork and i was cruzing at about 75 in my 90 gsx 5spd then this lady cut me of so i sped up to pass her and right while i was acclerating to about 85 my car started bucking and making a nasty noise. So i push the clutch in slowed down and let the clutch out agian and it was fine. Needless to say i didnt go 85 for the rest of the trip to my painter. i think my right fron strut is blown it clunks when i hit bumps a mechanic said that could be the problem. because at high speeds it might lose stability any other ideas? It felt like somthing was wrong drivetrain wise. I Also dont think it is boost related because i have ran full boost many prior times without problems. could it be a bad axle, ball joint, wheel bearing, clutch related or transfer case related? also could it also be a motor mount issue, fuel or spark issue?
Old 11-19-2005, 11:42 AM
4G63t Power 4G63t Power is offline
Re: car started bucking violently at 85mph
Are you sure you didnt just hit fuel cut? I know sometimes when i hit it itll jerk around and kick back on... just a though...
AWD sold
New car*
90' Eclipse Gs-T
Shaved head with rebuilt motor
Slowboy racing limited slip
compression 165 across the board (:
Fully ported Big 16g with 34mm flapper
Precision racing Fmic
Slowboy Boost controler set at 15lbs
Custom 3 inch turboback
Fully ported o2 housing
Ported 2g manifold
Slowboy racing UICP
3 inch hard intake pipe
SAFC
Autometer carbon fiber gauges
Putting down a solid 300whp
1/4=13.7 at 109
That mph is good for high 12's with traction (:
Old 11-19-2005, 11:47 AM
DonSor DonSor is offline
Yeah. Sounds like you were starving at hig speed. Could be fuel pump, fuel filter. Again ignition problem is a possibility.
Old 11-19-2005, 01:55 PM
Re: Re: car started bucking violently at 85mph
this is the 3rd time this has happend to me the first time i redlined first and put it in second and it bucked at me the second time i was agoing up a little hill went to 3000 in first put it in second and it bucked a little and now this last time cruzing in 5th push hard up to 85-90 and it bucks hard at me. so you guys think its fuel or ignition related. i also had a problem 3 weeks ago that went away my belts were squeeling really bad and when i would slow down my car would almost die and i could forget about doing a little 3 point turn around cuz it would die when creeping around. the belts one day stop squeeling and i havent had that problem since.
Old 11-19-2005, 02:02 PM
Gsx_hooptie Gsx_hooptie is offline
I'd replace the strut, since it's already a likely issue. If you're unstable at speed, it's a good bet. It'll also give you the washerboard effect, which isn't very cool. If you want to know how to test the strut before buying a new one, try compressing it in your hands and see if it slowly receeds. A sudden amount of pressure should lock it, so to speak.
I doubt it's fuel cut if you are boosting correctly. Checking for boost leaks could rule that out. Also, I don't know why it would be a spark issue if you were only affected from 85+. If it's not the strut or boost leak issues, I'd look into the wheel alignment and then transmission issues. Easy things first, though.
I-84, ah, my favorite in NY. Best road to speed on evar.
Edit>> I just missed your post by a few minutes. Um, I guess I'll have to write something else in a bit.
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
Old 11-19-2005, 02:33 PM
i think my strut is weak but it wouldnt have anything to do with the first 2 times and the stalling so. also i dont think i have any boost leaks besause i have ran full boost numerous times so thats why i think it is fuel related.im plan on bringing my car to a mechanic what should i tell him to look at? fuel wise that is.
Old 11-19-2005, 04:01 PM
ted_ex's Avatar
ted_ex ted_ex is offline
You might wanna check out the spark plugs. I had a problem a while back when I hit something in the area of 10-12 psi. It was intermitent for a while and occured until I put in the stock plugs. It's an easy and cheap thing you can do to help find the problem.
I'm>everything
Old 11-19-2005, 04:09 PM
ill check my spark plugs when i get my car back. what other checks i can do to see what the problem might be as far as wheel bearing cv joint and fuel?
Old 12-26-2005, 08:05 PM
avw0516 avw0516 is offline
Send a message via AIM to avw0516 Send a message via Yahoo to avw0516
Check the spark plug wires also, if one is loose on the coil pack it will give you the same feeling you described.
