Old 11-19-2005, 04:37 AM
cjflow cjflow is offline
Question OBD0 obd1 ecu info needed
Can you just get a Skunk 2 ecu and that solves the issue with obd0, obd1
Old 11-19-2005, 06:30 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: OBD0 obd1 ecu info needed
what does the skunk2 ecu do ?
Team Lonely Drivers
Old 11-19-2005, 09:17 AM
doug294 doug294 is offline
Send a message via AIM to doug294
IMHO they are a waist of money. Not to mention if your buying them off e-bay they are liekly fakes. For the price of one of those you can get a P28 or P06 (converted to a P28), chipped, and datalogging capabilities. Plus you would still be about $100 richer.
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
Old 11-19-2005, 09:19 AM
Oh forgot to add. No this will not be all you need for OBD1 conversion. You will need a 4 wire O2, OBD1 or OBD2 distributor, ECU jumper harness (unless you want to go through the pain of making your own) and a OBD0->OBD2 distributor jumper harness (again unless you want to make your own or hardwire).
Old 11-19-2005, 03:07 PM
Re: Re: OBD0 obd1 ecu info needed
Originally Posted by doug294
Oh forgot to add. No this will not be all you need for OBD1 conversion. You will need a 4 wire O2, OBD1 or OBD2 distributor, ECU jumper harness (unless you want to go through the pain of making your own) and a OBD0->OBD1 or OBD2 Depending on which dist you use distributor jumper harness (again unless you want to make your own or hardwire).
corrected
Team Lonely Drivers
Old 11-19-2005, 04:21 PM
Yeah sorry, nice catch man.
Old 11-20-2005, 12:22 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
ask yourself.............why do you need a skink 2 ecu for?
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
