Old 11-18-2005, 10:09 PM
phoneman007 phoneman007 is offline
Unhappy how to replace hub bearing
I Have A 2000 Taurus And A Roaring Noise Is Coming From Front End,i Took It To Tire Store To Have Tires Checked,they Said They Were Ok,sounds Like Hub Bearing,but Cant Tell From What Side The Noise Is Coming From.can Someone Tell Me How To A Dentify And How To Replace,,thanks
Old 11-20-2005, 06:38 PM
silver88lx silver88lx is offline
Re: how to replace hub bearing
Just have to have a good listen> Have someone stand or ride outside the car to pinpoint. The hub is replaced as an assembly.
Old 11-21-2005, 07:16 AM
mwt878991 mwt878991 is offline
Buy a Haynes or Chiltons manual. It will have detailed instructions on how to change it.
Mike
Old 11-21-2005, 11:11 AM
hughw hughw is offline
I have a 2000 ses and have just recently replaced the Hub.....
you cannot buy just the bearings ....Its an easy job with an expensive part...You have to buy the entire hub...about $90....and it is held in by only 3 bolts......The manuel says to remove the contral arm and all thats attached....but I had trouble removing the control arm because of the
spring......so I just tapped the axel in as far as it would go...(be careful to not hit too hard and damage the cv jount)...I was then able to remove the three bolts and replace the entire hub.....My problem was with the right (passenger side) hub....hopefully the left is as easy.
Old 11-21-2005, 01:31 PM
Willyum Willyum is offline
Drive close along a fence or wall both left and right with the windows down and a "co pilot" to see if the both of you can identify the noisiest side.
Old 11-21-2005, 02:16 PM
$64.99 at Autozone.
Mike
