Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-18-2005, 08:53 PM
gmcuajo gmcuajo is offline
Making a Piston fit
How I can make a Piston for the civic ZC fit on a D17A1-A2?
I can shave it or something like that?
Is more easy to found an aftermarket piston for any d16 or d15. I found a set of them, how I can make it to my d17a1 engine, beacause d17a1-a2 has a lower compression height?
Old 11-19-2005, 08:36 AM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
That ZC is a 1.6L, you can't put a smaller piston in there.
Old 11-19-2005, 10:18 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Making a Piston fit
just look for pistons for your d17 and don't try to cheap out and get the wrong parts.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 11-20-2005, 06:46 PM
As for all 01+ civic D17 isn't easy to found parts. I just see only one company that offers pistons for this engine, but those are for turbo. I think install an OEM Honda (OS 0.5mm), but .5mm of "overbore" doesn't make any change.
So found some for the ZC and cut some of the material to make it fit.
The ZC is a D-series, all D-series engine have the same bore (75mm), just change the stroke (D15, D16, D17: 84.5, 90, 94.4).
