Old 11-18-2005, 08:57 PM
swoopes30 swoopes30 is offline
Angry MY 95 blazer hell... code 175 system to rich ahhhhh!!!!!
ok heres the thing my blazer has a mind of its own. i changed the starter in it about a month ago. it was running a little funny then. like i knew it was running rich. i had the O2 SENSOR changed in it about a week in a half ago. after that the problem of it sputtering and vibrating at take off, and really bad gas mileage, and idleing horribly contunied also ONLY sometimes when i went to start it it would make a noise like i turned the key when it was already on. only it wasnt. i also went to advance autoparts and had the engine light seviced the code was "PO175 system to rich." they informed me that if the person installing the sensor didnt rest the computer (by takeing the cables off the battery) that it wouldnt take, so they deleted the code and it started to driver better?! only when i was idleing for more than 5 mintues the engine light came back on and the sputtering was not as lound or hard but still therer, it sounded like it was missing. sooo, i went home and took the cables off the battery and the problem went back to the way it was before the code was deleted. I was told that if i take the sensor out and spary it with carb cleaner that this will fix it? but im not sure if that is the problem any more if some one could help i would really apperciate it.!!!
thanxs liz
1995 blazer 4.3 vortex 4x4 in need of alittle help
Old 11-18-2005, 09:12 PM
Cailen Cailen is offline
Re: MY 95 blazer hell... code 175 system to rich ahhhhh!!!!!
Check the fuel pressure at the shrader valve. Look for the fuel rails going in to the back of the upper intake plenum. Post back your fuel pressure. You're supposed to be in the 60-65 range, I'm guessing you'll be lower.
Take off the IMTV valve and look inside the intake manifold. Shine a flashlight in there and see if you can see any puddles of fuel. If you're lucky it'll be completely black and carbony in there. My guess is you're one of the many unlucky 95 owners with a bad CPI. You may need to replace the CPI + Nut kit. Post back if you see puddles on the passenger or drivers side. Drivers side indicates a leak in your nut kit, passengers indicates a leaking fuel pressure regulator. If you replace the CPI I HIGHLY recommend doing the nut kit too (its not very expensive, and very worth your while)
Ever done a tuneup?
How does your oil look? You don't want to drive around with gas in your oil.
Originally Posted by blazee
If you would pull your f ing head out of your f ing ass and read the f ing thread, you will see that I posted the most common f ing cause in f ing post # 4 and Swalt followed it up with more f ing details in f ing post # 8. From what we f ing posted you should be able to f ing realize that if you have two new f ing tires on the f ing front and two raggedy ass f ing tires on the f ing back... that is probably causing your f ing bang. Try not to be such a tool. Can you do that, Thank you. f head!
Old 11-18-2005, 09:29 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
I hate CPI's....worthless. Good thing GM put out a recall on them. Get 'em changed over to CPSI by the dealer for free now......WEEEEEE!!
Old 11-18-2005, 09:37 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: MY 95 blazer hell... code 175 system to rich ahhhhh!!!!!
Ummm...no.
CPI's were never dealer swapped out.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-18-2005, 09:39 PM
BlazerLT's Avatar
AF -Advisor
thanxs liz
Remove your Vortec nameplate on the top of your engine.
Remove the round valve underneath it.
Take a flashlight and look down into the upper plenum and looks for golden silver washed spots and pools of fuel.
It should be black is there is no leaks.
Old 11-18-2005, 09:41 PM
You didn't get the memo? I had my '98 1500 W/T with a 4.3 and my '99 blazer both changed out, free.
Old 11-18-2005, 10:15 PM
BlazerLT's Avatar
AF -Advisor
This is a 1995, different injection system.
Old 11-18-2005, 10:27 PM
LT is describing the sequential injection system.
Unfortunately LT and I have both had to replace our CPIs out of our own pockets.
Old 11-18-2005, 11:31 PM
BlazerLT's Avatar
AF -Advisor
Yip, 1995 CPI injection system is not covered under any warranty.
Old 11-21-2005, 12:21 AM
Well, i guess i got free parts and labor then..:-)
Old 11-21-2005, 12:26 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
your 98 and 99 have the faulty spider unit on a sefi system that got changed out free, not the batch fired cpi
Old 11-21-2005, 12:28 AM
So when did they change over from CPI to CPSI?
Old 11-21-2005, 12:37 AM
in 97, and i beleve it went till atleast 05
Old 11-21-2005, 01:42 AM
BlazerLT's Avatar
AF -Advisor
1996 they changed from CPI to CSFI.
Old 11-21-2005, 09:08 AM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
not even a recall. its an expensive thing to out-of-pocket. i guess instead of recalling it and loosing money, they switched to CSFI with a throttle body
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
