radio install 2001 jeep grand cherokee loredo
i have 2001 jeep cherokee loredo i want to now if anybody can help? how do i take out the factory radio any help will be appreciated.
Re: radio install 2001 jeep grand cherokee loredo
The radio/vent trim bezel is held in place with 4 spring clips. With a wide flat tool (a 3" plastic spackle tool works great), gently pry on each vertical side and carefully pull the bezel out a little at a time until it is free. The red areas in the center picture are the felt-lined receptacles that the bezel spring clips fit in to, which shows the general area of where to pry when removing the bezel.
The radio is secured with four phillips screws, one in each corner. Slide the radio straight out and remove the wiring harnesse(s), antenna connector, and CD changer connector (if equipped). 1999-2001 models may have an additional single wire connector for the PCI connection and also a ground wire connection. |
