Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-18-2005, 07:23 PM
colombian911 colombian911 is offline
Unhappy i need help bad
when i press the gas in first second and third gear it runs good but then 4 o 5 gear the cars get like if u were pressing the brakes i dont know how to xplain like if jumps something like that and if i let go the gas a lil bit it goes back to normal and if i hold it down and press more when the turbo reach the max the car doesnt do that no more
Old 11-19-2005, 09:19 AM
inatalonIXLR8 inatalonIXLR8 is offline
Re: i need help bad
Try to keep the exact same question to just one thread. Like I said probably fuel cut.
95 Talon Tsi AWD 5spd
2.4L4G64 6bolt JE8.5EagleTorqueplatedFully ballanced-balanceshaftARP Ferrea1mm 1Ghead ported/polished HKS264/272 fidanzagears turbonetics copy polished GT3076R VbandTial38mm cometic prothane mounts SARD850 stage4 Compclutch+flywheel 3"exh Walbro255 rewired Innovate wideband O2 ForgeBOV Autronic standalone innovative wideband[url=http://img494.imageshack.us/my.php?image=talonandhelicopter5as.jpg]
Old 11-21-2005, 11:25 PM
Black97GST Black97GST is offline
Re: i need help bad
yep. Fuel cut.
Old 12-04-2005, 09:45 PM
gcobb gcobb is offline
Re: i need help bad
Ditto and it means you have several other issues to look into.
Old 12-06-2005, 01:56 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: i need help bad
boost leak test is necessary
now - 2000 civic
soon - 2002 is300
