Old 11-18-2005, 05:36 PM
ccrtw88 ccrtw88 is offline
Spark plugs
I bought Bosch Platinum 2+ spark plugs for my 99 blazer about 3k miles ago ( i know i shouldnt of bought them but it was before i found this forum). The packaging said that they were pre gapped. Well since i have heard all these bad things about them on here i decided to take one out and see what it looks like. The plug doesnt look to bad. One thing i saw though was that the gap was very small. When i put it on my gapper tool is showed about .02 . The haynes manual says they should be .06 . Are the 2 pronged spark plugs not supposed to be the same gap as single pronged?? Should i regap them all to be .06?
Old 11-18-2005, 10:50 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Spark plugs
Go get some AC Delco platinums and get it over with.
All you are going to get with that plug is problem.
No one here is going to waste their time helping you with such a bad plug.
It would be a waste of time.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 11-21-2005, 02:30 PM
Re: Re: Spark plugs
I havnt had any problems with the plug after 3k miles of use. Only real problem i have had is low gas mileage. That's why i figured i would check out one of the plugs and thats when i noticed the gap size. I just dont want to go out and buy a whole new set of plugs when mine are working fine. I was just wondering if the gap size could be lowering my gas mileage.
Old 11-21-2005, 04:42 PM
Cailen Cailen is offline
Re: Spark plugs
After 10k kilometers of use on my truck's previous owner's bosch 4s I had one or two cylinders not firing, and the rest blackened and sooty.
Replace them with AC delco plats or rapidfires (I prefer the rapid fires personally).
Do you use the plats or the rapids LT? I've heard a lot of good about the rapidfires, especially for us northerners.
Originally Posted by blazee
If you would pull your f ing head out of your f ing ass and read the f ing thread, you will see that I posted the most common f ing cause in f ing post # 4 and Swalt followed it up with more f ing details in f ing post # 8. From what we f ing posted you should be able to f ing realize that if you have two new f ing tires on the f ing front and two raggedy ass f ing tires on the f ing back... that is probably causing your f ing bang. Try not to be such a tool. Can you do that, Thank you. f head!
Old 11-21-2005, 05:51 PM
Gabe25's Avatar
Gabe25 Gabe25 is offline
Re: Re: Spark plugs
Switch to AC Delco plugs. Your blazer will thank you for it. Not to mention the money you'll save on Extra Strength Tylenol.
1994 1st.Gen. S10 Blazer Tahoe
Aloha
Gabe
My Fleet
Old 11-21-2005, 07:01 PM
JC327's Avatar
JC327 JC327 is offline
There's a reason everyone is telling you to switch. Those plugs will cause you trouble, they do not work well in our Blazers, and they will cause problems down the road. Save yourself alot of headache and extra work and go ahead and replace them.
Old 11-21-2005, 07:23 PM
93LT 93LT is offline
I'm still not clear here. Are you all recommending the Bosch spark plugs?
Old 11-22-2005, 09:10 AM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Re: Spark plugs
I can recommend Bosch Supers (Copper plugs) and standard Bosch Platinums. But the +2/3/4 varieties are plain old junk in our engines. THe reason why *I* like the plain old Bosch Supers in my '95 is because for the same heat range and engine application that the standard AC/Delco plug cross-references for - the Bosch are a full 1/4" shorter! Just the trick for getting the #3 plug swapped out with only one skinned knuckle.
Old 11-22-2005, 10:11 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Spark plugs
Don't forget the amount of people that have had problems with the standard Bosch plat's as well wolfox.
They still misfire like crazy.
Old 11-22-2005, 10:24 AM
jsgold jsgold is offline
has anyone had problems with Autolites? The local Advance store stopped stocking the AC Delco plugs for my truck so I used Autolites last tuneup. I have used them on other vehicles but I notice a slight misfire when the engine is hot. Not bad, but not something I have not been able to diagnose.
I used to be indecisive, now I am not so sure.
Old 11-22-2005, 10:49 AM
BlazerLT's Avatar
AF -Advisor
Re: Spark plugs
Autolites don't waork exactly well with GMs for some reason. They do work great for fords though.
From what I have heard from my friend, they don't last to long and tend to wear out really fast.
Old 11-22-2005, 10:51 AM
Re: Spark plugs
autolites are shit in GM. Parts stores sell them because they provide some nice perks for the reps behind the counter (ie whoever sells the most, or meets a certain quota gets a trip to Mexico).
Old 11-22-2005, 07:00 PM
Well I hate to change out a fairly new set of platinum plugs, but, perhaps worth a try. I no longer have a stalling problem, just a minor skip/miss when hot at idle. Maybe plugs misfiring. Guess I will have to buy plugs elsewhere, ditto on wires(schmucks no longer stock AC Delco wires either for my truck.) I suppose I could have them special order them but damn, should not have too.
Old 11-22-2005, 08:34 PM
Re: Spark plugs
Bought AC Delco wires from my Dealership for 35.00, that was the wholesale price, list would be about 25% more, but the wires fit.
Old 11-23-2005, 02:22 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Spark plugs
Yea, the wires with the 90 degree cap connections are actually quite cheap.
