Old 11-18-2005, 05:23 PM
bruno77 bruno77 is offline
No parking lights
Have 95 windstar, the parking lights (running lights) do not work. Turn headlights on and that is all that comes on, no rear lights. Have checked fuses and replaced headlight switch. What am I missing?
thanks!
Old 11-21-2005, 09:24 PM
wiswind wiswind is offline
Re: No parking lights
Fuse #9 powers all the "parking" lights.....that includes the license plate lamps, front (yellow) parking lamps, and the rear (red) parking lamps.
The Hazard / turn signals use a different circuit.....although they use the same bulbs for front and rear as the parking lights.
Wire color to each bulb socket, BROWN for the Parking function.....Light Green for the Hazard/turn signal function, and Black for Ground.
Old 11-22-2005, 07:24 AM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: Re: No parking lights
Hay WisWin
Do the parking lights use a Maxi fuse? You know the larger ones under the hood?
I thought about this when I first read this post but didn't have a real good wiring diagram to check it out.
Dan
Old 11-22-2005, 02:50 PM
rrclyoung's Avatar
rrclyoung rrclyoung is offline
I had a 95 sable that lost the parking lights, rear tail lights and the dashboard lights.....I found it to be bad (melted wiring) at the headlight switch connector. I don't know if your dash lights work or not....but this seems to be a widespread problem because the 1st 3 cars (taurus/sable) i went to in the wrecknig yard for the replacement harness had the same problem, or at least the start of it.
Old 11-22-2005, 04:43 PM
[The dashboard lights work, in fact all other lights work properly. I appreciate the responses above and plan on checking them out this evening.
Old 11-22-2005, 05:43 PM
Steffe Sweden Steffe Sweden is offline
Send a message via MSN to Steffe Sweden
I did have the same problem vid my car
I can tell you that I found a Power modul for the rear parking light and I found that on the right side in the rear.and here in sweden it cost 3500 sek. so I did a new wire to the rear ligts with a relä and fuse
Old 11-22-2005, 06:17 PM
The fuse for the "parking" lights is a 10amp "mini" fuse....it is in the "Instrument Panel" fuse block....which is by the driver's left foot (for those of us in countries which drive on the righthand side of the road). I am not sure which side U drive on in Sweden....so I don't want to just say "driver's side" if you drive on the left hand side of the road.
I am refering to electrical diagrams that are at www.alldatadiy.com
A subscription is required.
