Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 11-18-2005, 04:13 PM
malegail malegail is offline
fuel pump problem
I have a 90 Sunfire. Installed 3rd fuel pump recently...each time I replace pump it works for a few months and then fuses start blowing....then eventually I have to replace pump. have replaced relay. Could it be pressure regulator?
Old 11-19-2005, 10:23 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: fuel pump problem
There are several things that can cause fuel pump failures. If the regulator is causing the pressure to stay too high it can cause premature failure. Second, make sure you don't run the fuel tank too low. Fuel keeps the pump cool and if the tank gets too low then the pump will overheat and draw too much amperage and blow the fuses. Finally, make sure that you aren't getting a lot of water in your fuel. This can cause corrosion and cause the pump to fail. Use a bottle of gas line antifreeze periodically if you believe you have a lot of water in the fuel.
Old 11-19-2005, 12:11 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
I would check the fuel pump ground.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-21-2005, 06:41 AM
TheGuyz TheGuyz is offline
Check wiring harness on pump and wires around sounds like may have weak or bad cable causing issue.
Also verify installed properly.
